techedge question???
Old Jun 7, 2004 | 12:23 AM
boosted_dc2's Avatar
Default techedge question???
i have one and it has 2 plugs coming off the display. one plugs into the control box and the other doesnt go to anything. it looks the same as the one that goes into the display, is it for dataloging??? if so how do i do it???
Landon
Old Jun 7, 2004 | 02:17 AM
swlabhot's Avatar
Default Re: techedge question??? (boosted_dc2)
If you have the version 2A0 and LD01 display then you should have 2 cables supplied. The long one goes from the LD01 to the WB (serial to RJ45). The short one goes from the WB into the serial port on your laptop. Thw WB only has one RJ45 port so you can only run only one at a time, either your LD01 or laptop for datalogging. I just hook the WB to laptop when I tune and datalog, once its done I hook back up the WB to the display
Old Jun 7, 2004 | 09:30 AM
Default Re: techedge question??? (swlabhot)
what program do i need to datalog with it??? i have 2 plugs
Landon
Old Jun 7, 2004 | 10:12 AM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">what program do i need to datalog with it??? i have 2 plugs
Landon</TD></TR></TABLE>
TEWBLOG its $20 and can be found on the techedge site.
Old Jun 7, 2004 | 11:51 AM
swlabhot's Avatar
Default Re: techedge question??? (ndogg)
Its actually free. You only pay $20 if you want to use the built in 'Autologging' and 'Alarms' features. You can datalog perfectly without these features. They are just nice to haves.
Old Jun 7, 2004 | 03:11 PM
ndogg's Avatar
it used to be free... they started charging for it now. or i just paid $20 for nothing.
Old Jun 7, 2004 | 08:33 PM
what do i need to log rpm's with it??? thanks for the help.
Landon
Old Jun 7, 2004 | 08:45 PM
keebler65's Avatar
if you have two plugs coming off of the display, then you have an older model. are you using 1.0 or 1.5? if you're using 1.5, you should be able to make a cable that would go from the DB9 connector on the controller to your laptop to log.
Old Jun 8, 2004 | 02:54 AM
Default Re: techedge question??? (keebler65)
its the 1.5 version. are there instructions on how to make the plug???
Landon
Old Jun 8, 2004 | 01:35 PM
keebler65's Avatar
there are pinouts on the website: http://www.wbo2.com
1995b18b1cx
Honda S2000
May 6, 2006 10:57 PM
Amused
Dec 13, 2005 08:14 AM
VTformula
Honda Motorcycles
12
Nov 4, 2004 12:04 PM
honda9369
Sep 11, 2004 08:28 PM
KCDelSol
May 13, 2003 01:27 PM
