tdo4-h
Old Dec 17, 2005 | 01:28 PM
EH-3's Avatar
Default tdo4-h
whats the bolt pattern on the compressor? is it the same as a t3 or t4?
Old Dec 18, 2005 | 09:50 AM
TheShodan's Avatar
Moderator
Default Re: tdo4-h (EH-3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH-3 &raquo;</TD></TR><TR><TD CLASS="quote">whats the bolt pattern on the compressor? is it the same as a t3 or t4?</TD></TR></TABLE>
That is a Mitsubishi Heavy Industries turbo, and has NOTHING to do with the T3/T4 Garrett manufacturing series at all. They share NO components for that application. THe TD04H uses a a ring seal to hold the compressor housing on, not bolts.
Make sure you study up on the differences physically and thermodynamically of the 2 companies.
Old Dec 18, 2005 | 10:03 AM
CoreyR's Avatar
Default Re: tdo4-h (TheShodan)
im guesing he means the turbine housing and no its not even close to a garret 4/5 bolt housings.
Old Dec 18, 2005 | 11:12 AM
EH-3's Avatar
Default Re: tdo4-h (CoreyR)
i meant where the compressor bolts to the manifold. is the bolt pattern similar? but from what im reading, im assuming not. but what kinda bolt pattern( that bolts to the manifold) is it? and the greddy td04-h not the mitsubishi, or are they the same?
Old Dec 18, 2005 | 11:14 AM
CoreyR's Avatar
greddy used mitsu turbos if im not mistaken. youll need a mitsu t25/14b flange
Old Dec 18, 2005 | 11:15 AM
CoreyR's Avatar
and its the turbine, compressor is the part where the air comes out of.
Old Dec 18, 2005 | 12:03 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH-3 &raquo;</TD></TR><TR><TD CLASS="quote">i meant where the compressor bolts to the manifold. is the bolt pattern similar? but from what im reading, im assuming not. but what kinda bolt pattern( that bolts to the manifold) is it? and the greddy td04-h not the mitsubishi, or are they the same?</TD></TR></TABLE>
A) the turbine bolts to the compressor
B)the patterns are nowhere close
C)greddy uses mitsubishi turbos
Old Dec 18, 2005 | 12:41 PM
EH-3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">greddy used mitsu turbos if im not mistaken. youll need a mitsu t25/14b flange</TD></TR></TABLE>
so the part that bolts the turbo to the manifold is the flange right? so the bolt pattern on the flange is that of a t25/14b? thats what i was tryin to ask.
Old Dec 18, 2005 | 05:20 PM
CoreyR's Avatar
so the part that bolts the turbo to the manifold is the flange right? so the bolt pattern on the flange is that of a t25/14b? thats what i was tryin to ask. </TD></TR></TABLE>
correct.
Old Dec 18, 2005 | 06:36 PM
TheShodan's Avatar
Moderator
Even the T2 Flange is different than the DSM 14B turbo..
Old Dec 18, 2005 | 06:38 PM
CoreyR's Avatar
t2 is what, garretts t25 style?
Old Dec 18, 2005 | 08:01 PM
EK k kay's Avatar
The Greddy TDO4H is a modified Mitsubishi turbo with a Garrett T2/T25/T28 flange. The same flange is found on the Silvia T25 and T28, Greddy 15G, 18G, and 19T turbos, and the ball bearing Garrett GT28RS (probably found on other GT series turbos as well). This flange is not the same as the Mitubishi T25 flange or any other Mitsubishi flange.
Old Dec 18, 2005 | 08:11 PM
CoreyR's Avatar
Default Re: tdo4-h (EK k kay)
so greddy does use the garrett style flange?
Old Dec 18, 2005 | 09:30 PM
p0gi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">so greddy does use the garrett style flange?</TD></TR></TABLE>
yes
Old Dec 19, 2005 | 12:55 AM
EH-3's Avatar
Default Re: tdo4-h (p0gi)
thanks for the clarification
neoc03
Oct 20, 2008 07:36 PM
huepowered
Feb 1, 2006 10:03 PM
SEFIxCivic
May 27, 2005 10:56 AM
Bontke
Jan 28, 2003 05:15 PM
