TD04-specs
I got my hands on a free TD04L-12T of an Volvo T5 (220bhp 2.5l)
now i was not supposed to go turbo, nitrous was my choice, but when given a free turbo why not have a little fun first
now i'm wondering what specs it has.
according to this info i have an A/R of ((35*35)*PI)/50= A/R 77 and
an compressor trim of (36*36/44*44)x100 = 67 trim and
an turbine trim of (44*44/50*50)x100 = 77 trim
these numbers seem a little odd to me
these are the specs i measured
inducer compressor: 36mm diameter
exducer compressor: 44mm diameter
inducer turbine: 50mm diameter
exducer turbine: 44mm diameter
inlet turbine: 70mm diameter
please correct me if i'm totally of, i'm new to FI.
here are some pics
here are some pics
i don't know what year, model
i actually got it from someone at mitsubishi, brand spanking new
they said it was one before the newest so this one became obselete
just getting a free turbo might not be the best reason to get your car boosted. Your going to be spending $1000+ if you piece together everything else you need to run the car successfully
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR99 »</TD></TR><TR><TD CLASS="quote">just getting a free turbo might not be the best reason to get your car boosted. Your going to be spending $1000+ if you piece together everything else you need to run the car successfully</TD></TR></TABLE>
why is that?
200 euro for ecu (chipping, moates ostrich and crome)
100-200 ebay intercooler
100 intercooler piping
100 exhaust piping
200 for misc, oil lines, injectors(lude ones) and other lines such as vacuumlines
the wideband is something i already have and need for my future K-build
the 3inch exhaust (i'm going to run front side exit first for a while)i'm gonna need for my K too
the fuelpump (not nessecary for my goal of 200whp) is needed too for the K
gauges are included in my wideband display
so i will be going 800-1000 out of my way towards my K, sell the kit for probably 1000+ euro and gain a lot of exp
i said i'm a "noob" at FI, not without skills/knowledge
but thnx for the concern, it could just be that i did not knew what i was getting myself into
p.s. i got room to learn it the hard way, i can blow 2 engines and still have one in mint condition for daily driving
why is that?
100 exhaust piping
from what people have said about that turbo, you can blow in it and it should spin. it would be fine on a d15, the only har part would be a dp flange. everything else is built in
but can someone confirm that the specs i've measured come to an
a/r off 77
turbine trim of 77 and a
compressor trim of 67
and what boost can i safely run to stay under 190 whp, don't want to blow while getting the hang of tuning
a/r off 77
The Greddy kit for the D series uses a TD04-15. I have one on a D16 in a EG and it is at full boost at around 3500 rpm. I run it at 10-11 lbs of boost everyday. It is fun to drive. It will spin the tires in second gear. As far as the flange for the DP you could probably order one from Turbonetics.
