TD04 Oil Feed Fitting ? ?
Old Feb 14, 2005 | 08:45 AM
turbor850's Avatar
Default TD04 Oil Feed Fitting ? ?
Hey guys,
does anyone know the oil feed fitting on the TD04 turbos ?
Is it 12 X 1.5 MM ?
Thanks
Old Feb 14, 2005 | 08:53 AM
BlackT5's Avatar
Go ask somewhere else you nub
Seriuosly tho, just unscrew the stock banjo bolt and if you can't read the threads, take it someone who can
Old Feb 14, 2005 | 08:55 AM
beepy's Avatar
Default Re: TD04 Oil Feed Fitting ? ? (turbor850)
It is an IF fitting, either 1/2" or 3/8" IF depending on year of production. Go to the auto parts store and have a look at their preterminated brake lines. You can attach the brake line to an AN hose by using a tube nut and tube sleeve. (-3AN works with 3/8" IF, -4AN works with 1/2" IF)
Old Feb 14, 2005 | 09:06 AM
project dc2's Avatar
Default Re: TD04 Oil Feed Fitting ? ? (beepy)
i think its 7/16th -24 inverted flare.
Black R
Feb 20, 2005 03:12 PM
Del_Slowest
Oct 22, 2003 03:48 AM
importboi22
Oct 15, 2003 07:46 PM
jwork101
Mar 21, 2003 05:38 PM
BlackGSR
Apr 7, 2002 06:11 PM
