Tapping new sources for vacume................
Old May 12, 2002 | 04:34 PM
intekragsr's Avatar
Default Tapping new sources for vacume................
Ok, when I get my AVCR tommrow, I will be tapping new holesin the intercooler piping.
My question is, does it matter what size the lines are? Today I bought a 1/8" npt to a 1/4" hose. I thought the bigger the better. Will a 1/4" hose work for tapping in the boost controller? Please let me know. Thank you.
Old May 12, 2002 | 04:47 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Tapping new sources for vacume................ (intekragsr)
yes.
Old May 12, 2002 | 04:48 PM
intekragsr's Avatar
Default Re: Tapping new sources for vacume................ (not so civic)
sorry, im confused, yes it does matter? or yes i can do it?
Thanks
Old May 12, 2002 | 04:53 PM
SEFIxCivic's Avatar
in my opinion with a smaller diameter hose you get more consistant vacuum readings.
Old May 12, 2002 | 04:58 PM
intekragsr's Avatar
Default Re: Tapping new sources for vacume................ (SEFI8LOxCivic)
hmmmm.......i see your point. Does any one else got any opinions?
Old May 12, 2002 | 05:03 PM
Mr. Vapor's Avatar
i would also like some new vac points, where is it recommended to tap my I/C piping? also what type of fittings should i use? just a threaded 1/8 NPT fitting? how do i make it air tight? teflon?
Old May 12, 2002 | 05:05 PM
intekragsr's Avatar
Default Re: Tapping new sources for vacume................ (NYb16)
im planning on JB weld
Old May 12, 2002 | 05:47 PM
shadowdawn's Avatar
IC piping??? Why would you tap into IC piping, everyone hear told most people to tap off a POST throttle body line ONLY... reason being IC piping never reaches vacumm, only the intake manifold does.... something to that effect....
Old May 12, 2002 | 05:50 PM
SEFIxCivic's Avatar
you must put the ports after the throttle body otherwise you'll have a boost port and not a vacuum port. what i do is take off the intake manifold and drill holes where it has a lot of meat for thread. sounds like a lot of work... but i guess thats what seperates a regular install from a professional quality install.
intektra
that's not necessary, and i highly advise you not to use jb weld. a npt thread is tapered so as you screw it in the fitting it gets progressively tighter. they make a pipe thread sealant which you apply to the fitting, so its air tight.
Old May 12, 2002 | 05:52 PM
GruvyTune's Avatar
New User
Default Re: Tapping new sources for vacume................ (shadowdawn)
you are correct. The intake tubing never reaches vacuum only atmospheric or boost. You have to be past the throttle body which is at vacuum most of the time unless boosting (or WOT in NA cars). The only reason to tap the intake pipe is to make a fitting for your electronic boost controller solenoid but even that is not necessary as you can take it off the compressor.
Old May 12, 2002 | 06:44 PM
intekragsr's Avatar
Default Re: Tapping new sources for vacume................ (GruvyTune)
Ok, the only reason I am doing this is for an EBC. I dont have a hole in my compressor
Old May 12, 2002 | 06:49 PM
GruvyTune's Avatar
New User
then yes before the throttle body! definitely not after if its for and EBC.
Old May 12, 2002 | 08:39 PM
intekragsr's Avatar
thank you
cbstudd77
Nov 29, 2006 05:38 AM
misskris220
Jul 7, 2005 04:54 PM
Midwestrider
May 11, 2003 10:06 PM
yellow blur
May 6, 2002 05:01 PM
