taking out the a/c
Old Feb 26, 2006 | 02:10 PM
Turbo_TONY's Avatar
Default taking out the a/c
are there anything special things or tricks to takin out your a/c?
Old Feb 26, 2006 | 02:20 PM
Dunc's Avatar
BCICAN
Default Re: taking out the a/c (Darkside_DC2)
Make sure your car is off and the freon* is out.
Old Feb 26, 2006 | 02:21 PM
Turbo_TONY's Avatar
Default Re: taking out the a/c (Dunc)
Old Feb 26, 2006 | 02:34 PM
iBrandon's Avatar
Yes be very sure the freon is OUT!
Old Feb 26, 2006 | 03:14 PM
SOHCD16y8's Avatar
Default Re: taking out the a/c (iBrandon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">Yes be very sure the freon is OUT!</TD></TR></TABLE>
Or just open it up and run away while it sprays out. Thats what I had to do, everywhere local to me wanted 20 bucks to pump it out with the machine.
Old Feb 26, 2006 | 06:12 PM
Dunc's Avatar
BCICAN
Default Re: taking out the a/c (SOHCD16y8)
hmmmm $20 oorrrrr massive fines.....I'll do the $20. If you can't afford $20, you're in the wrong section of H-T.com
Old Feb 26, 2006 | 06:13 PM
kylemarhx's Avatar
what car is it coming out of? i'll buy the parts from you if it's out of a 5th gen.
Old Feb 26, 2006 | 06:17 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">hmmmm $20 oorrrrr massive fines.....I'll do the $20. If you can't afford $20, you're in the wrong section of H-T.com</TD></TR></TABLE>
Whos gonna see it, and even if they do you need proof, not a big deal in Northwest Indiana, the cancer causing smog is a bigger problem
Old Feb 26, 2006 | 06:34 PM
Schister66's Avatar
Man U FTW
I worked for the past two summers at a heating and AC place and do you know that you can be fined $10k for releasing that into the air.......just FYI
Old Feb 26, 2006 | 06:46 PM
SOHCD16y8's Avatar
actually its 14,975 by where I live. Yes I checked at the town hall and they could provide any means for me to get it removed for free so they pretty much told me indirectly to just release it. And dont act you like guys have never heard of or no someone if not odne it before yourself. I can name at least10 members on this board off the top of my head who have done it before. Dont act like its so terrible to do when it happens all the time. Im not sayiong I approve, in fact Id love to not release it, but not if Im going to have to pay for it.
Old Feb 26, 2006 | 06:51 PM
stewie8apie's Avatar
Default Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">Or just open it up and run away while it sprays out. Thats what I had to do, everywhere local to me wanted 20 bucks to pump it out with the machine.</TD></TR></TABLE>
Old Feb 26, 2006 | 06:56 PM
97CWITR's Avatar
https://honda-tech.com/zerosearch
Old Feb 26, 2006 | 07:11 PM
Turbo_TONY's Avatar
Default Re: taking out the a/c (96BLkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BLkGSR &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch</TD></TR></TABLE>
I already searched before i posted. I always do. I couldnt find anything. If you guys can find anything id love to get the links.
Old Feb 26, 2006 | 08:01 PM
Dee's Avatar
Dee
You do realize you just made yourself look like an asshat since people have already given him some semi-helpful advice.
Old Feb 26, 2006 | 08:23 PM
Turbo_TONY's Avatar
Default Re: taking out the a/c (Dee)
i already knew about getting the gas out. And ya about having th car OFF.lol. I was basically asking if it was just as easy as taking the gas out...unbolting it ..and takeing the belt of. Ive got a 94 Teg by the way.
Old Feb 26, 2006 | 11:28 PM
EnzoSpeed's Avatar
Default Re: taking out the a/c (Turbo_TONY)
Freon? Cars don't use freon anymore. Modern cars use R34 (aka Airsoft gas propellant) which is harmelss to the environment. I vent that **** into the atmosphere all the time.
And no, there are no special tricks to removing the a/c system. It's cake - you can do it in an hour. The only part you might not think of is that you have to remove the evaporator box, pull out the evaporator, then re-install the box to retain a functional vent/heater.
Old Feb 27, 2006 | 06:01 AM
SOHCD16y8's Avatar
93 and some 94 models still use the old R12 which is slightly harmful to the enviroment. Everything newer came with the R134.
Old Feb 27, 2006 | 08:15 AM
piece of cake...just make sure your face isn't near the compressor when you detatch the hose it's nearly impossible to get ALL the gas out..so some might still come spraying at you
Old Feb 27, 2006 | 01:21 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote"> Dont act like its so terrible to do when it happens all the time. </TD></TR></TABLE>
Big difference between what should happen and what does happen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Freon? Cars don't use freon anymore </TD></TR></TABLE>
Wow can we be anymore nit-picky? You got the point as to what I meant.
Old Feb 27, 2006 | 04:34 PM
EnzoSpeed's Avatar
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">Wow can we be anymore nit-picky? You got the point as to what I meant.</TD></TR></TABLE>
Well freon destroys the ozone layer, and 134a is harmless, so I'd say it's more like bringing up a valid point that being nit-picky.
Old Feb 27, 2006 | 05:03 PM
suspendedHatch's Avatar
Default Re: (EnzoSpeed)
Well I just removed mine and I can't think of any advice to give you. There are a lot of little things that people always forget. The relays, the idle pulley. You can either detach the engine mount or just cut off the belt. Super easy.
Old Feb 27, 2006 | 05:14 PM
Muckman's Avatar
Moderator in Chief
Any AC shop should take it out for free. R134a is reusable and at $10 a pound, everybody wins.
Old Feb 27, 2006 | 05:18 PM
Hybrid96EK's Avatar
Well freon destroys the ozone layer, and 134a is harmless, so I'd say it's more like bringing up a valid point that being nit-picky.</TD></TR></TABLE>
Might be "valid" if you had a CLUE what you were speaking of..
http://www.earthscape.org/r1/etf01/khb01.html
"As a gas, HFC-134a has a significantly larger global warming potential (GWP=1300) than many non-halocarbon working fluids. This means that emission of HFC-134a causes a significantly larger effect on global warming, compared to an equivalent amount of carbon dioxide (GWP=1 by definition)."
Old Feb 27, 2006 | 06:55 PM
SOHCD16y8's Avatar
Default Re: taking out the a/c (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Any AC shop should take it out for free. R134a is reusable and at $10 a pound, everybody wins.</TD></TR></TABLE>
Not around here they wont.
Old Feb 27, 2006 | 07:43 PM
EnzoSpeed's Avatar
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Might be "valid" if you had a CLUE what you were speaking of..</TD></TR></TABLE>
How about you go kill yourself for being ignorant? Stop thinking you know what you're talking about because you did a quick google search.
134a is called "Green" gas for a reason - it's environmentally friendly. That's the whole reason why it replaced R12 in the early 90's. That's also why it's illegal to dump R12 into the atmosphere but perfectly legal to dump 134a.
Do you think airsoft guns would be dumping millions of pounds of this gas into the air if posed a problem to the environment?
P.S. link does't work
