t-25 adapter plate!?!?!?!? PLEASE HELP!
Old Aug 28, 2002 | 03:36 PM
T25 civic's Avatar
Default t-25 adapter plate!?!?!?!? PLEASE HELP!
I just got my HF manifold in the mail, and I was putting it together to see what everything looks like, and the idiot drilled the holes wrong!? If I use this adapter plate, not only is the center hole way screwed up (completly the wrong shape and size) but the turbo would mount with the exhaust outlet facing the block (not really facing it, but probably THROUGH it) and the intake side of the turbo would be facing the front bumper! I really need an adapter plate made, please someone help me out!
Nick
Old Aug 28, 2002 | 04:35 PM
sutrusu's Avatar
Default Re: t-25 adapter plate!?!?!?!? PLEASE HELP! (T25 civic)
you know you can rotate the compressor housing on the turbo right?
Old Aug 28, 2002 | 07:55 PM
T25 civic's Avatar
Default Re: t-25 adapter plate!?!?!?!? PLEASE HELP! (sutrusu)
yes I realize that but its not that which is causing the problem. imagine you have your turbo bolted to the manifold. Then you unbolt the turbo, and rotate the whole turbo 90 degrees. that way instead of going from the left to the right, it goes from the front to the back. That way its hitting (or going through) the block, it just won't work! The idiot didn't drill the plate right so now its useless.
HELP SOMEONE. I need either a new manifold or another adapter plate.
Nick
[Modified by T25 civic, 4:56 AM 8/29/2002]
Old Aug 29, 2002 | 06:31 PM
T25 civic's Avatar
anyone? All the places I've checked are selling them for 100 dollars or more.
Old Aug 29, 2002 | 06:48 PM
turbod16y8's Avatar
http://thenew.gamesbbs.com/~turbosi/ try this he sells the apter plate for 65 dollars.
ion_four's Avatar
try to post a pic of it. maybe someone can have a suggestion that way.
Old Aug 29, 2002 | 06:57 PM
T25 civic's Avatar
Default Re: t-25 adapter plate!?!?!?!? PLEASE HELP! (ion_four)
There are no pictures of the adapter plate or the turbo on my computer, but the adapter plate is useless, it cannot be saved. Would I be better off trying to find a company that sold a manifold with the t-25 flange already on it or what?
Nick
Old Aug 29, 2002 | 07:40 PM
turbod16y8's Avatar
hey read the post i post earlier for u they sell adapter plate for a hf mated to a t25
Old Aug 29, 2002 | 07:42 PM
Smashback's Avatar
You might want to look into one of the un-welded universal log manifolds w/T25 flange. Probably cost less money AND grief..
Old Aug 29, 2002 | 07:47 PM
T25 civic's Avatar
Default Re: t-25 adapter plate!?!?!?!? PLEASE HELP! (mplex2000)
Where could I find one of those? Brands, links?
Nick
Old Aug 29, 2002 | 07:50 PM
legendboy's Avatar
https://honda-tech.com/zerothread?id=244011&page=2
turboteg95
Mar 22, 2007 03:42 PM
crxY-49
Apr 15, 2003 08:11 AM
civicraca
Jan 8, 2003 06:08 PM
