symptoms of blown engine ???
Old Jun 8, 2002 | 03:17 AM
Cyber ITR's Avatar
Default symptoms of blown engine ???
can u guys list the symtoms if u have a blown engine please ??
i was driving tonite , and i heard a loud boom when i was braking
im so scared now
Old Jun 8, 2002 | 03:27 AM
degradated's Avatar
New User
Default Re: symptoms of blown engine ???
smoke...
I really don't think you blew your engine while braking.
Old Jun 8, 2002 | 03:32 AM
Cyber ITR's Avatar
Default Re: symptoms of blown engine ??? (degradated)
smokes from where ????
btw ur avatar scared me
Old Jun 8, 2002 | 05:24 AM
Ri5e's Avatar
Default Re: symptoms of blown engine ??? (VTEC_SiR)
Low compression. Blow by (Smoke coming out from your valve cover breather, smoke coming out from the oil pan dipstick hole). Car feels weak off the line (or Stalls out when you stop).
Old Jun 8, 2002 | 07:15 AM
93LSivic's Avatar
Default Re: symptoms of blown engine ??? (BG Boost)
Kinda like whats goin on with my car.............
Fawk, I was hoping that the JE's and Eagles wouldnt have to come til the winter. Oh well, more boost, more hp, lower ET's here I come.
Old Jun 8, 2002 | 02:45 PM
Cyber ITR's Avatar
Default Re: symptoms of blown engine ??? (93LSivic)
no smokes coming out from breather , dip stick , havent check the compression yet
it still goes very hard , but i dunno if it just my imagination or something , i notice my engine sounds like a wrx ???
hmm its blowing grey smokes from the exhaust tho (@hi revs , @ WOT)
is grey smokes from burning oil and fuel at the same time ??
[Modified by VTEC_SiR, 12:13 AM 6/9/2002]
Old Jun 8, 2002 | 03:37 PM
MiraiZ's Avatar
Blue smoke = oil burning
Is this from your tail pipe
also check for exhaust leaks...this could explain the WRX-like exhaust note...
Old Jun 8, 2002 | 03:47 PM
Cyber ITR's Avatar
Default Re: symptoms of blown engine ??? (MiraiZ)
yupe greyish smokes coming out from the tailpipe
leak in the exhaust system makes sense , cuz the pipe always got new scratches everytime i went thru a bump
Old Jun 8, 2002 | 04:18 PM
MiraiZ's Avatar
If its out of your tail pipe then you may have bad rings or valve stem seals. But since you mentioned scaping on bumps...you may want to check for oil leaks as well....things to check for (in order of severity)
1. Check for a clogged or damage PCV valve...replace it if needed
2. Oil too thin...use thicker oil.
3. Oil leak somewhere (close to exhaust or under valve cover)
4. bad seals in turbo on the exhaust side...
5. bad valve stem/ seals
6. bad oil rings
7. pistons damaged, warped, or cracked
8. sleeves cracked
Old Jun 8, 2002 | 04:19 PM
Anthony K's Avatar
New User
im so scared now
Maybe you just backfired from running rich? I don't know.
Old Jun 9, 2002 | 05:28 AM
Cyber ITR's Avatar
Default Re: symptoms of blown engine ??? (Anthony K)
nope pretty sure wasnt a backfire
it sounds more like *boom, clank, clank*
but it still drives fine , even tho well not sure it sounds like a wrx
integra_101
Mar 16, 2010 09:39 AM
2 0 3
Sep 7, 2006 03:02 PM
adeline
Jul 22, 2005 02:20 PM
McNizzle
Jan 31, 2005 03:14 PM
sutekidane
Oct 27, 2003 08:58 AM
