Supra Pump???
the factory supra turbo pumps will not flow good at high (100+) fuel pressures... it will work great if you have a dfi setup with low fuel pressures... those pumps are verry quiet for the amount they flow
The Supra pump is good for about 350~370 HP. A lot of shops over here use Supra and GTR pumps.
BBK and Holley intank pumps a‚’e Walbro pumps that are repackaged and@maked up. These pumps are best used when used with 1:1 FPR's since they do not like the fuel PSI required to run FMU's..
[Modified by drealgsr, 6:05 AM 7/2/2001]
Pretty much the same thing, endyn bosch fuel pump...is probably the best one to get. If you go with the walbro make sure you get the 255lph high pressure pump so that it will work with your fmu.
The High Pressure Walbro being the Forced Induction Holley? http://www.holley.com/HiOctn/ProdLin...FP/InTank.html
A little something to read. It says that the pump puts out almost twice the amount of fuel as the regular 255LPH pump at 80 psi. Is that the pump that you are talking about when you say 255LPH high pressure Walbro? Or was there another pump in mind. I want a pump that will be good for about 10 psi of boost.
i run a Walbro 255lr/hr high pressure pump in my turbo honda..works great. I boost ~15psi without problems.
I bought it for $109 from auto performance engineering in texas. Its an awesome intank pump..it was just plug in and install. DIdnt have to modify one wire.
liam
liam
