Supra Help
Old Apr 9, 2003 | 07:30 AM
DC2_GSR's Avatar
Default Supra Help
I have a '95 Toyota Supra Non-Turbo and want to swap it out with a 2JZ-DET. What kind of turbo would be best to go with it to make 400-500 whp? Would i need a bov? Internal work? exhuast manifold?
Old Apr 9, 2003 | 07:40 AM
EpDarks's Avatar
Default Re: Supra Help (DC2_GSR)
If you swap a stock 2JZ-GTE (not DET like you thought...), you can make 400+ WHP from the stock twins. Downpipe, exhaust, air intake/filters, boost controller, and some tuning, and your on your way...
If you want to make some CRAZY numbers, you can always do a single turbo conversion. A stock Supra block can ussually take upwards of 700 WHP, especially if the turbo is big enough...
You can also get aftermarket twins, a little harder to tune, but much less lag. You'll ALWAYS need a BOV, and an aftermarket manifold. Like I said before the Supra block is INSANE! You probably DON'T need any internal work, if anything get a nice crower cam.
If you got the money, do a single-T conversion. You can get small enough turbos to have a little less lag (maybe a T66 or a 60-1?), or a massive turbo (T88) and you'll have crazy peak Hp numbers.
Don't forget the dyno time to get it running right...
Good luck.
Old Apr 9, 2003 | 08:19 AM
civicudesire's Avatar
i recommend going twin t88's,lag wont be that bad
i swear about a few years ago on mkiv.com i saw someone who did this,wish i could find the post
ramboPandA
Feb 4, 2015 07:15 PM
yungkhmer
Feb 15, 2012 02:51 PM
AccordtypeT
Oct 1, 2009 04:36 PM
meloylo
Jul 3, 2008 07:11 AM
bigfattom
Jan 14, 2002 05:59 PM
