supra fuel pump?
if you need more lph and want to keep the intank fuel pump you could always run one of those voltage raisers like the kenne-bell boost-a-pump,aeromotive fuel controller and i believe msd has one,they raise the current too like 18-24 volts without heating up the fuel. with one of those an walbro 255 would go well past 300lph,i bet probably close too 400lph.
[Modified by D-Man, 5:35 PM 11/27/2002]
I ran a bosh relay, instead of main relay, voltage went from 10 volts with main realy to 14 volts with a deticated relay direct from battery. Pump sound a whole lot meaner, and it has lasted for 2 years that way.Jason
i am runing a 95supra tt pump in my crx, i ran bigger gauge wire and a relay with the 12volt mod, the pump fit like stock i was even able to put the stock sock on it with no modifications, cant even tell its not stock
