Is this supposed to happen? (A/F ratio question)
Old Mar 24, 2003 | 08:08 AM
oryanh's Avatar
Default Is this supposed to happen? (A/F ratio question)
I hooked up my wideband O2 last night. (the tech edge kit)
I noticed I'm pretty spot on (14.6-14.8) most of the time... Except when I let off the gas, it spikes to 20:1+...
Is that normal?
Also, at WOT I'm around 12.2:1 - 13:1 Can I lean this out a bit?
What's a safe WOT A/F ratio?
____I'm runnning 01 ITR- NA, with 2.5 Header, high flow CAT, and V-AFC.____
Old Mar 24, 2003 | 08:19 AM
Bottoz's Avatar
Default Re: Is this supposed to happen? (oryanh)
Yes you can adjust it, but its easier with a Standalone. You're best bet is to log a bunch of runs. The parameters to look at are A/F, Engine Speed, Engine RPM, Knock and Throttle Position. Then you can review exactly what your car is doing, and adjust the fuel table.
As far as the 18+ A/F on deaccelleration...I get the same thing. I haven't looked at the Accel/Deccel settings yet of my AEM EMS, but I plan too.
Bottoz
[Modified by Bottoz, 10:22 AM 3/24/2003]
MikeMAN's Avatar
if ur stock, honda does a good job managing fuel. and when u let off the gas, its normal to spike to 20:1..because u don't need much fuel to just coast
mike
Old Mar 24, 2003 | 08:41 AM
RGAZ's Avatar
New User
Is that normal?
Everything you noticed is completely normal. Under no-load conditions the engine runs extrememly lean by design.
Randy
Old Mar 24, 2003 | 10:53 AM
oryanh's Avatar
Default Re: Is this supposed to happen? (RGAZ)
Sweet... Thank you!
How about a safe A/F for an NA setup?
...under load.
bboyPHOENIX
Jul 14, 2014 02:29 PM
Ash J. Williams
Engine Management and Tuning
Jan 10, 2013 07:01 AM
balbowskie
Apr 26, 2012 06:37 PM
EG6 Poe
18
Dec 6, 2007 08:00 AM
Extent
Aug 23, 2002 07:03 AM
