what size turbo should I get??
I'm shooting for in between 380-420 whp on my gsr. should I go with 60-1/t3 or just another t3/t4. if so what A/R and trim should I look into. also are 720cc's to large for these hp numbers??
some motor specs.
GE sleeved block (stock bore)
JE 9:1 pistons
Crower rods and I'll be using Hondata 2b
some motor specs.
JE 9:1 pistons
Re: what size turbo should I get?? (92JDMSiR)
You can use a T3/T4E and make up to 400whp. the T3 60-1 turbos are great for Hi power also. I have access to both turbos if your interested..??or check the Classified FI forum. MATT3T4 has them posted.
Re: what size turbo should I get?? (MotorMatrix.com)
two quick question, turbo let say 57trim 63a/r which is intake compressor and exhuast compressor? would 60trim 63a/r to make 320whp be to big and have to much lag on b18c1 running 11psi?
