Supercharger help please
Old Feb 28, 2009 | 12:17 AM
boostinaintez's Avatar
Default Supercharger help please
Hey guys. I just installed a jrsc onto my friends del sol with a d16z6. After install it is running really really rich. It instantly fouls out the spark plugs. I upgraded the following during supercharger install.
Crower stage 1 cam (lashed correctly), adj. cam gear, extended the iat, purge solenoid, and tps, walbro 255, and a step colder plugs, insulated intake gasket, fuel pressure gauge (which is spot on). Supercharger was used and I never heard it run before.
I have 550cc injectors for it but I left the stock ones in so I can drive it and get tuned swapping the injectors when I get there. This car ran perfect before the supercharger and cam install. Does anyone have any ideas of what could be causing this. Fue
Old Feb 28, 2009 | 12:32 AM
Default Re: Supercharger help please
Actually I might be on to something. I got a used cam and I double checked the part numbers and it shows that its for a d16y8 engine. I've got a z6. I don't think these are compatible are they....?
Old Feb 28, 2009 | 04:32 AM
Pleiadi79's Avatar
Check crower website i'm quite sure they don't fit, maybe lift is too highv at inlet timing too long.. Did u replaced fpr with one adjustable? Maybe pump it's too powerful without correct fpr setup
Old Feb 28, 2009 | 08:13 AM
Alright cool I think I'm going to switch back to stock and see what happens. Any other suggestions?
Old Feb 28, 2009 | 08:33 AM
Jaker's Avatar
All you need to do is adjust the camgear by about 4.5 degrees. The difference bewteen the Y8 and the Z6 cam is about 1/2 a tooth on the cam timing. The easy way to know if you have it adjusted the right way is if you can get your ignition timing correct (close to the middle of the slots) with a timing gun (around 14 degrees). If you can't get it there, adjust the cam gear the other way 4.5 degrees.
Old Feb 28, 2009 | 08:44 AM
Went through the cam gear stuff and got that correct and it still runs like crap. It can't even idle on it own. Misfiring and with black smoke out the back.
Old Feb 28, 2009 | 09:24 AM
Jaker's Avatar
Any chance you have the purge solenoid and the IAT plugs mixed up?
Old Feb 28, 2009 | 09:48 AM
daveb91's Avatar
FMU or ECU setup??
Old Feb 28, 2009 | 09:56 AM
Ecu setup and I double checked all the electrical and it checked out fine.
Old Feb 28, 2009 | 12:06 PM
Jaker's Avatar
Is the Walbro the 255 high pressure version or the regular? If it's the HP version, look here:
http://www.theoldone.com/articles/regulator/
Are you boosting at all yet (I hope not)?
Old Feb 28, 2009 | 12:14 PM
Pleiadi79's Avatar
sparks cables order inverted? if still smokes check airfuel ratio, did u did it?
Old Mar 1, 2009 | 07:41 AM
Spark plugs are correct order and the fuel pressure is correct. I have a gauge attached. I have an aftermarket regulator that I put on just in case and it still did the same thing. Is there any way a bad supercharger could cause this? When I rev it up it doesn't sound like it should. Its not whiny at all.
Old Mar 1, 2009 | 01:12 PM
Jaker's Avatar
Show us some pics of the install, close up. Any chance the bypass valve is not getting the correct vacuum reference?
neocrynym
Nov 15, 2008 03:36 PM
Marcpb443
Oct 27, 2006 10:12 AM
roberts
66
Jul 17, 2006 05:38 PM
