Supercharged B16A build.. need some help..
Old Dec 25, 2009 | 10:41 AM
jose_SPEC-944's Avatar
New User
Default Supercharged B16A build.. need some help..
I have a B16A and a Jackson Racing supercharger and I am doing a complete build what is the best setup i can use to get the most power but maintain reliability... I was thinking to sleeve the motor and use the JUNE stoker kit... that all i got so far any suggestion??
Or does anyone know of a better setup i can use??
Thanks
Old Dec 25, 2009 | 03:05 PM
New User
Default Re: Supercharged B16A build.. need some help..
I am going to get the T-sleeves from AEBS. I am most likely going to go with the JUNE stroker kit but before I make the decision is there any other kits that you all will recommend?
Old Dec 28, 2009 | 05:08 PM
New User
anyone?
Old Dec 28, 2009 | 09:21 PM
johnls's Avatar
Originally Posted by jose_SPEC-944
anyone?
aftermarket pistons,rods and a turbo should do sell the supercharger
Old Dec 28, 2009 | 10:04 PM
stock95coupe's Avatar
The JRSC will not make enough power to tax your b16 to the point of failure. Even with a ported head, high-lift cams, a spectacular header, ported blower, and LHT aftercooler - you're looking at ~300hp max. If you are looking for >50k miles on the setup, you may want press-fit forged pistons, but that's about all. This all assumes it's going to be tuned with more than an FMU and v-afc...
People only blow stock sleeves above 300hp with a jacked tune, or above 500hp with a good tune.
Old Dec 29, 2009 | 08:05 PM
bossm's Avatar
imho its not worth getting a stroker kit why not just go b20 sleeved and make real power with a jrsc but not a stroker kit and b16 supercharged will not make that much power at 9 psi your looking at 230 with a good tune and anything above that i would run a lht intercooler but they still are fun
Salvatorie
Oct 29, 2011 07:15 PM
1750cc
Sep 1, 2005 09:17 PM
teg92
Sep 7, 2004 08:21 AM
spoolineh2
Nov 9, 2003 07:26 PM
Screamer
Dec 10, 2001 05:03 PM
