Suggestion for Cams? B16/CTR
Old Jan 28, 2005 | 03:32 PM
1SlowSi's Avatar
Default Suggestion for Cams? B16/CTR
I have a stock B16A2 right now and im about to throw on the turbo and tune next week. I have a set of CTR cams int/exh. What should i use? I dont want to have to dyno with B16 cams then later on take out the cams, put CTR's in dyno again. If i lose power, then ill have to swap again. With whatever i choose, ill have to stay with 0,0 on the cam settings because i dont have any moon cuts or opening to adjust while dynoing. What do you suggest?
Old Jan 28, 2005 | 03:47 PM
Ek00fbp's Avatar
Default Re: Suggestion for Cams? B16/CTR (1SlowSi)
put the ctrs in they are tried and true just look up I think it was boostfed who gained tons of power switching from b16 cams to ctrs.
link: https://honda-tech.com/zerothread?id=704660
Old Jan 28, 2005 | 04:06 PM
1SlowSi's Avatar
Default Re: Suggestion for Cams? B16/CTR (Ek00fbp)
yeah i saw that.. but damn he's got 600whp! im only wanting 300. Did he tune out the overlap that CTR's have? i dont know. All i do know is that i have no way of adjusting my cam gears unless i pull off the valve cover. So 0,0 is all i got to work with. Its either Si or CTR's.
Old Jan 28, 2005 | 04:36 PM
Ek00fbp's Avatar
also, its not that hard to borrow someone elses valve cover on your tuning day. Alot of tuners have them around the shop too.
Old Jan 28, 2005 | 04:43 PM
1SlowSi's Avatar
good point. I hope Mase has one.. lol.
Old Jan 28, 2005 | 04:55 PM
Aggressive Racing's Avatar
use the ctr's dont bother with the stocks.
tbud454
39
Apr 20, 2004 05:14 PM
crxste
Jun 24, 2003 06:13 PM
SuperCivic
19
Jun 28, 2002 07:09 PM
All Motor EG
May 13, 2002 10:42 PM
