Stuff to seal a fitting on the fuel rail??
Old Dec 24, 2001 | 02:23 PM
GSRwBOOST's Avatar
Default Stuff to seal a fitting on the fuel rail??
i have an AEM fuel rail I just stuck on my car and the bolt on the end tward the driver side has a very almost unnoticable leak... we are talking very tiny... but with any type of leak I don't want it....
i was told not to use teflon tape... and there is liquid stuff but i looked at autozone but dont know the name of it.. and the person I know locally that knows what it is isn't available...
fuel fitting thread type stuff??
Old Dec 24, 2001 | 02:37 PM
GruvyTune's Avatar
New User
Default Re: Stuff to seal a fitting on the fuel rail?? (GSRwBOOST)
teflon pipe thread sealer
Old Dec 24, 2001 | 08:13 PM
degradated's Avatar
New User
Jake, I got your message.
Fuel rail install was easy, huh? I just used teflon tape to seal mine. I think as long as you wrap it counterclockwise so that it doesn't shred when you tighten it down, it will be okay. Put about 4-5 layers of tape on that bolt and I guarantee you won't be leaking anymore. Just make sure none of it is going to shred off to plug your injectors.
Old Dec 24, 2001 | 09:21 PM
DragII's Avatar
25 Year Member
Default Re: Stuff to seal a fitting on the fuel rail?? (degradated)
I like "liquid teflon" better than the teflon tape.
Old Dec 24, 2001 | 09:55 PM
degradated's Avatar
New User
well yeah...liquid teflon is better, but for now the tape will work until you can find some of that stuff. I don't really know where to find it.
Old Dec 24, 2001 | 10:11 PM
Smashback's Avatar
Napa baby!
Old Dec 24, 2001 | 10:12 PM
DragII's Avatar
25 Year Member
Default Re: Stuff to seal a fitting on the fuel rail?? (mplex2000)
I got mine from home depot, in the plumbing section
Old Dec 24, 2001 | 10:23 PM
Smashback's Avatar
I meant the liquid sealant, tape can be had from the Depot for sure though!
Old Dec 25, 2001 | 05:54 AM
DragII's Avatar
25 Year Member
me too
Liquid teflon can be found at home depot.
Old Dec 25, 2001 | 07:38 AM
GSRwBOOST's Avatar
Default Re: Stuff to seal a fitting on the fuel rail?? (DragII)
I used several wraps of teflon tape on the threads.. I think the fuel rail threads are long enough to cover the entire bolt/threads and teflon so none is sticking out. It seems to be not leaking... and i hope the above is true.. i dont want any chances of clogging up an injector and worse...
Old Dec 25, 2001 | 08:33 AM
Big James's Avatar
New User
My AEM was the sam way. However, I noticed that t stil leaked with the liquid teflon. I ended up using a little bit of HondaBond.
Old Dec 25, 2001 | 12:29 PM
degradated's Avatar
New User
hehe, they say in the fuel rail instructions "Use liquid teflon to seal, DO NOT USE TEFLON TAPE".....but mine seems to be hanging in there.
Jorsher
13
Jan 19, 2010 04:52 PM
95DC2GS-R
Aug 2, 2009 04:19 AM
acmoc
10
Dec 15, 2008 05:06 PM
johnwohl
Feb 10, 2008 11:07 AM
SlowB16
May 8, 2002 10:48 PM
