striped trans mount bolt
Old Sep 9, 2008 | 10:41 AM
b18 hatch mike's Avatar
Default striped trans mount bolt
what should i do that one bolt is striped woud be fine just running 2
Old Sep 9, 2008 | 11:28 AM
totsie7944's Avatar
Default Re: striped trans mount bolt (b18 hatch mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike &raquo;</TD></TR><TR><TD CLASS="quote">
what should i do that one bolt is striped woud be fine just running 2 </TD></TR></TABLE>
lol I did the same thing when I got solid mounts....the mounts were thicker than stock and the stock bolt was too short and not enough threads were in the hole when I started torqueing it down apparently. Anyway, you should be fine with just 2. However did you consider getting a tapping kit and tapping the threads? Or even a chaser kit and chasing the threads and ordering a longer bolt from ARP?
Old Sep 9, 2008 | 05:02 PM
DaveF's Avatar
put all of the bolts in there
you can get a metric heli coil kit at your local autoparts store. if you dont want to heli coil it, get out your tap and die set, tap it, and then go to the hardware store for a bolt/washer of proper size and length.
Old Sep 9, 2008 | 05:49 PM
Default Re: striped trans mount bolt (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">put all of the bolts in there
you can get a metric heli coil kit at your local autoparts store. if you dont want to heli coil it, get out your tap and die set, tap it, and then go to the hardware store for a bolt/washer of proper size and length. </TD></TR></TABLE>
i might try to find heli coil wish me luck have not seen any this big that i can remember
Old Sep 10, 2008 | 09:50 AM
what thread pattern is the thransmission mount bolt? pretty sure its a m12 x 1.25
Old Sep 10, 2008 | 10:56 AM
evokidvii's Avatar
Default Re: (b18 hatch mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike &raquo;</TD></TR><TR><TD CLASS="quote">what thread pattern is the thransmission mount bolt? pretty sure its a m12 x 1.25</TD></TR></TABLE>
correct
Old Sep 10, 2008 | 08:55 PM
Default Re: (evokidvii)
lets hope so doing this tomorrow had to get a 31/64 drill bit
sol_1
Aug 11, 2008 05:21 PM
Bob_760
May 17, 2007 10:37 PM
BJOnewiper
Dec 10, 2005 01:15 PM
xkhalil333x
Dec 24, 2003 12:49 PM
88 rex
Jul 24, 2003 02:18 PM
