Strange Voltage problem... Think its Hondata related...
Here is my setup...
2000 Civic Si
b16a2
Custom Kit
Hondata S200 w/ boost, datalogging, & rom editor w/ p28 ECU
Boomslang Xover Harness
I just put in my digital voltmeter, and I began noticing something... While on throttle at any percentage, voltage drops, sometimes as low as 12.0 volts. When I am on Decel in gear, the voltage quickly climbs back up, but when I hit the throttle to any level, the voltage begins to drop.
Also, I notice that my volt gauge reads anywhere from .3 to .7 volts lower than my blitz turbo timer... Both are tapped into the same wire, directly to the ignition. I am going to solve that problem by tapping my multimeter into the same wire and see which is more accurate.
Should I disconnect the ALTC wire from the ECU Harness? Will this throw a CEL? Will this cause over/under voltages?
2000 Civic Si
b16a2
Custom Kit
Re: Strange Voltage problem... Think its Hondata related... (ladysman)
you sure? Thats it? Damn... Time to get ahold of hondata and reinstall the rom editor software... LOL
Re: Strange Voltage problem... Think its Hondata related... (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi »</TD></TR><TR><TD CLASS="quote">you sure? Thats it? Damn... Time to get ahold of hondata and reinstall the rom editor software... LOL </TD></TR></TABLE>
With similar problems I have had with Hondata systems, this fixed it.
Good luck.
Good luck.
Cool... I'll give it a whirl... It was weird... this morning it didnt do it the first time i drove it, but the 2nd time i drove it, it did...
Alt-C wire - just unpin it and see what happens. This has been the fix to many people using Hondata.
danny98r
01-16-2005 07:51 AM
ebpcivicsi1234
01-14-2005 04:45 PM
