STR intake manifold problem?
Old May 23, 2004 | 02:32 PM
TurboB18C1's Avatar
Default STR intake manifold problem?
Will have a STR intake manifold i bought while back form ebay, the color is black... and it makes a noise simmilar to a vacum leak, the postion of this hole is right under the IAC and when i plug it the car starts to run at a very low rpm of 495 or so. So i took it for a drive and came back and noticed there has been a error code loged by the honda logger so i unplug the hole and start the car drove around again it drove just fine, but the hole is no sucking air again...
-should i put a pvc valve there / check valve / filter
-I dont know what it does under boost if there is an vacum leak or not.. the boost gague just stays steady
I know that hole has to stay open in order for the IAC to work properly but i dont understand... there should be no holes that are open on the manifold...
IT DID NOT COME WITH ANY INSTRUTIONS! DAM IT
Old May 23, 2004 | 04:07 PM
m R g S r's Avatar
Default Re: STR intake manifold problem? (TurboB18C1)
That hole on my manifold (It's a venom, so pretty close) is covered by the throttle body. The stock intake manifold has the hole in the same spot and it goes into the throttle body also. Are you using an aftermarket TB?
Old May 23, 2004 | 04:21 PM
TurboB18C1's Avatar
Default Re: STR intake manifold problem? (m R g S r)
NO i have the stock TB so it does go somewhere , so where does it go.. should i take off my map sensor and but a nipple there and connnect a hose from there to the hole..?
Old May 24, 2004 | 09:26 AM
THE GAME IS THICK's Avatar
post a pic buntizzle...
Old May 25, 2004 | 10:46 AM
TurboB18C1's Avatar
anyone
Old May 25, 2004 | 11:54 PM
TurboB18C1's Avatar
Does anyone have any thoughts... or am i posting in the wrong thread please correct me...
Old Jun 5, 2004 | 05:32 PM
ramennoodles's Avatar
I have the same manifold on my turbo integra. mine is a b18b though. it has the same hole on the bottom. it only opens when the car is cold or if the ac is on. it doesn't open during boost.
Old Jun 5, 2004 | 05:42 PM
slim9300's Avatar
Default Re: STR intake manifold problem? (600gixxer)
I think that posting a pic is the only way to get an accurate answer.
Old Jun 5, 2004 | 05:48 PM
Jared's Avatar
Default Re: STR intake manifold problem? (slim9300)
pretty sure the nipple you're talking about is the one that feeds air to the iacv when its open.
Old Jun 5, 2004 | 09:42 PM
Default Re: STR intake manifold problem? (Jared)
yeah, the hole on the bottom feeds the air into the aic. instead of drawing in air from the throttle body like the stock manifolds, it draws air from the outside. making it sound like a vacuum leak. theres nothing wrong with it. thats just the way they designed it
Old Jun 6, 2004 | 08:53 AM
TurboB18C1's Avatar
should i put a small filiter on it or just leave it...
Thanks for your information ...
Old Jun 6, 2004 | 05:57 PM
it a pretty small hole, I never had a problem with any thing getting sucked in.plus the aic also has a screen filter already in it
jpm3071
10
Jun 9, 2015 12:39 PM
norcalem2
Jun 7, 2012 09:26 AM
Black Ack
Jan 6, 2007 12:04 AM
Circa
Apr 2, 2006 07:05 PM
