Intake manifold failure
Hey guys,
One of the tubes of the intake manifold rusted and cracked so theres fluid that is coolant that is leaking all over. Has this happened to anyone and is there anyway to patch up the manifold or do I have to get a new one?
talks to himself
Re: Intake manifold failure
What?
Coolant doesn't pass through the intake manifold. Your problem isn't the intake manifold. Your problem can be any number of things and you're going to have to be more descriptive.
Also, ready the stickies. You're required to post the vehicle make, model, and relevant modification. Otherwise, we can't help you.
talks to himself
99 Honda Civic EX vtech
Its the intake manifold. Air goes from the intake, to the throttle body, through the intake manifold and into the head. The metal tubing that connects rubber tubing with coolant to the manifold rusted out and cracked so its leaking coolant and making the car overheat. According to my mechanic he said the entire piece needs to be replaced.
PHANTOM MENACE
I think we all understand what an intake manifold is and how it's used, you're not clarifying what tube you're referring to. If it's the one I mentioned above you can try to JB weld it if you feel lucky. If the manifold itself is fully intact and the tube is the only part that is damaged you should be able to remove it and use a threaded tap to install you're own threaded bung if you like. But until you clarify what tube you're talking about it's difficult to give you any sort of solid advice.
Pictures are worth a thousand words.
Post pictures please.
talks to himself
24Ten, it sounds like he's talking about the exact same thing you mentioned.
The bronze fitting that's threaded into the manifold. Shown right above #22 in this picture (it doesn't have a number)
PHANTOM MENACE
Yep that's my guess as well. I don't know if it's threaded though, might be press fit? Anyways, now that there's a diagram OP please confirm if that's what you're talking about.
