STR intake manifold Need instructions!!?
Old May 12, 2003 | 06:49 PM
TurboB18C1's Avatar
Default STR intake manifold Need instructions!!?
Can anybody email me the instructions on the STR intake manifold because mine make a annoying whistle sound… plus i boguht the dam thing on EBAY
Email – turbo_b18c1@sbcglobal.net
or post them
Old May 12, 2003 | 10:34 PM
ProStock MaMa's Avatar
Default Re: STR intake manifold Need instructions!!? (TurboB18C1)
call them if you need help
909-272-2150
info@strpower.com
Old May 13, 2003 | 12:08 AM
earl's Avatar
Default Re: STR intake manifold Need instructions!!? (AllMotorMama)
How is your engine vacuum?
Old May 13, 2003 | 12:51 AM
ninesecrx's Avatar
Default Re: STR intake manifold Need instructions!!? (earl)
The whistle sound might just be your intake sound getting more air from whatever the source is.
Old May 13, 2003 | 04:29 PM
TurboB18C1's Avatar
-410 at ideal
Old May 13, 2003 | 04:36 PM
Flamenco-T's Avatar
did you check for vac leak ?
410 is kinda high...
stan
Old May 13, 2003 | 04:40 PM
TurboB18C1's Avatar
Default Re: STR intake manifold Need instructions!!? (Flamenco-T)
yeah i did spary alot of Carb Cleanner all around the Vacum sources, but i did not find any leaks, but there is one thing on the intake manifold that is always sucking in air, i dont know if it takes a vacum hose or not because when i put a hose there my cars ideal drops to 413 rpm but when i dont it goes back to normal??!
Old May 13, 2003 | 05:03 PM
boosted_dc2's Avatar
check your coupler on your throtle body. my buddies was doing the same thing and it turned out there was some air "whistling" by the coupler.
Old May 13, 2003 | 09:59 PM
earl's Avatar
Default Re: STR intake manifold Need instructions!!? (hooked_up_gsr)
also check your manifold gasket on the bottom side. I assume you used a new one?
Old May 13, 2003 | 10:01 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i did spary alot of Carb Cleanner all around the Vacum sources, but i did not find any leaks, but there is one thing on the intake manifold that is always sucking in air, i dont know if it takes a vacum hose or not because when i put a hose there my cars ideal drops to 413 rpm but when i dont it goes back to normal??!</TD></TR></TABLE>There should be no holes left open anywhere on the manifold
Old May 14, 2003 | 03:31 PM
TurboB18C1's Avatar
i did use a new one, the hole that is left open is a very small in diameter and if it is used were does it go or what vaccum hose fits there ???
--------------------------------------l
l
Back of the manifold l Thortlle body
l
-----------------------------II-------l
The two II's are the hole on the cheap intake manifold drawing
Old May 14, 2003 | 03:34 PM
earl's Avatar
Could just be an extra port. Just plug it if you don't need it.
speeds's Avatar
i have the hole in the my str manifold too. i think it suppost to there
Old May 14, 2003 | 03:35 PM
speeds's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Could just be an extra port. Just plug it if you don't need it.</TD></TR></TABLE>
when i plug it the engine die
Old May 14, 2003 | 03:45 PM
TurboB18C1's Avatar
Default Re: STR intake manifold Need instructions!!? (speeds)
my car does not die it just drops the idle very low , the main concern that i have is there was no hole on the intake manifold for my pvc vaccum to connect to?? i am going to post some pictures later on i just need to charge my cammera
Old May 14, 2003 | 03:47 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeds &raquo;</TD></TR><TR><TD CLASS="quote">
when i plug it the engine die</TD></TR></TABLE>There can be no open holes anywhere in any intake manifold. Something else is wrong. Try adjusting the stop on your throttle body to open it more. You must start by plugging the hole and work from there.
I would assume if you have the engine running and you rev it up a little and then plug the hole with your finger, the engine keeps running?
Old May 14, 2003 | 10:57 PM
BDL IND's Avatar
That is an optional vacuum port. You can plug it up or use it as a port. If you do plug it adjust your throttle body to allow more air. You may have turned it down to the vacuum leak/ open port prior and not realized that was it. give us a call 909-272-2150 If you have any other questions.
Old May 14, 2003 | 11:02 PM
1fstevo's Avatar
New User
I remember the old style STR manifold does have a small port that was left open since I installed them several times. The port is not open to inside the manifold but leads between IAC and out side air source. If I remember correctly, on stock manifold, IAC get air source through a small hole that extend outside of the the mani reaching to the throttle body. Because STR sheet metal mani don't have that passage, IAC rely proper idle air source from that little port. Note: If you look at it closely ( held it up against the light), you can see the port leads to one of the two port IAC get air source from.
As for the whistling sound, try to tighten the throttle body bolts that attach to the mani some more, I had that problem once.
Old May 17, 2003 | 08:19 PM
TurboB18C1's Avatar
Default Re: STR intake manifold Need instructions!!? ([Evo]Hybrid)
Yea my intake manifold is the older one of the str line up and if i block that vaccum hole my car gets an CE code of 14 which is indicates IAC valve falut, another thing is that i am running a stock gsr TB on this large intake manifold but i did find a leak it was on my vaccum tank there was a hose hanging from the tank and was not conected to anything else.. man when i blocked that my car was back to normal.. but it still makes that noise.. im guessing its becuase of stock TB
Old May 20, 2003 | 10:51 PM
1fstevo's Avatar
New User
you sure the sound is not coming from that little port which is sucking air in to idle so it's making the whistling sound? Doesn't matter what TB especially stock, it should not make a whistling sound.
jpm3071
10
Jun 9, 2015 12:39 PM
ArchAngel Sabastian
Oct 14, 2001 09:02 PM
bong
Jun 12, 2001 02:47 AM
