Stock Valves or Crower????
Old Dec 29, 2006 | 07:33 AM
SOHCD16y8's Avatar
Default Stock Valves or Crower????
I have a set of crower valves that were used for about 100 miles sitting around that I was going to use for my current head built. I was thinking about it for a while though and began to wonder whether or not I should use them. I figure the head will be revved to about 8200-8500 depending on when the power really starts to fall off. I dont see any reason why I cant just use the stock valves on this motor. Would the stock valves seat better in the vave seats then the crower's would? Basically I just want you input on whether to use the crower or not. Im mainly just worried about the valves sitting and sealing as good as the OEM ones will.
Setup
B18b1 head
Crower valve springs/retainers
Edelbrock victor x mani
Crower 404 cams
Thanks guys
Old Dec 29, 2006 | 09:33 AM
b18sihatch's Avatar
Default Re: Stock Valves or Crower???? (SOHCD16y8)
its really up to you weather or not you would use them, i personally would use them just becuase i already have them sitting around, they couldnt hurt
Old Dec 30, 2006 | 12:08 AM
SOHCD16y8's Avatar
Hmmm, anyone else? Also if anyone is located in the NW indiana chicago area do you know where I can pic up some Permatex Prussianblue?
Old Dec 30, 2006 | 03:36 AM
zexxbo's Avatar
Default Re: (SOHCD16y8)
crower ftw. yea its supposedly safe to rev to 8.5k with stock valves but ive seen many a car throw a valve going to redline and im sure you wont have any issues seating the crowers properly assuming your shop does a have decent valve job. it'll also be better in case your power doesnt drop off then and you want to rev higher
Old Dec 30, 2006 | 04:30 AM
snaileg's Avatar
if its sitting around use it
Old Dec 30, 2006 | 09:29 AM
SOHCD16y8's Avatar
Default Re: (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">crower ftw. yea its supposedly safe to rev to 8.5k with stock valves but ive seen many a car throw a valve going to redline and im sure you wont have any issues seating the crowers properly assuming your shop does a have decent valve job. it'll also be better in case your power doesnt drop off then and you want to rev higher</TD></TR></TABLE>
Shop...What shop. Yeah I probably will end up using the crower's but I really need to find some prussianblue to check valve seal before I fully assemble the head. Thanks guys.
Old Dec 30, 2006 | 09:39 AM
b18sihatch's Avatar
you could easily get some aftermarket viton valve seals for your head, while its apart i would replace what needs to be replaced to make it all good
Old Dec 30, 2006 | 10:21 AM
SOHCD16y8's Avatar
yeah thats a given, I have all new OEM seals sitting waiting to go in. All im waiting for is my orde of Prussian Blue to get here so I can check my valve seat before final assembly.
turboman2.2
Jul 4, 2010 10:08 AM
bks84
Aug 25, 2008 10:17 AM
LU
Mar 16, 2005 01:07 PM
LsBack
Sep 19, 2004 01:04 PM
Big Josh
May 8, 2003 09:03 PM
