STOCk SR20 Dyno Graph
Old Jan 28, 2005 | 01:12 PM
SE-Rawkus's Avatar
Default STOCk SR20 Dyno Graph
Stock FWD SR20... As you will see, the car ran pretty rich on the dyno..didn't get a chance to clean it up because it was a dyno day The 2 dips in the graph was because of the rich condition where the car started breaking up (fuel blowing out the spark?) I will be street tuning the car in the upcoming week
344.39 WHP & 287.36 TQ @ 16 psi. I'd figure if I clean the a/f a bit, I can get the car to about 360/295 @ 16 psi.
<U>For bigger image click here:</U>
http://www.floridasr20s.com/ga...ull=1
Old Jan 28, 2005 | 01:47 PM
hYbRiD EeEkAy's Avatar
Default Re: STOCk SR20 Dyno Graph (SE-Rawkus)
nice numbers manny!!! definitely repping for your nissan crew! looking good.
this is EcKo from iSM
Old Jan 28, 2005 | 01:48 PM
Stripped Si's Avatar
stock as in stock head/block?
Old Jan 28, 2005 | 01:50 PM
RyanEJ8's Avatar
Seems like you went real rich in the middle of the graph there. Is that on the stock turbo?
Old Jan 28, 2005 | 01:58 PM
PM-Performance's Avatar
you should clarfy stock , because that isnt stock .
maybe stock motor, but i know they can handle more than that.
Old Jan 28, 2005 | 03:08 PM
SE-Rawkus's Avatar
Default Re: STOCk SR20 Dyno Graph (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">you should clarfy stock , because that isnt stock .
maybe stock motor, but i know they can handle more than that. </TD></TR></TABLE>
Apparently, I need to be more potically correct when I come and post stuff on this forum
By stock, I meant stock bottom end. The only mod that is inside the engine is a set of JWT S4 cams. Other than that, everything is is a put together kit.
Like I stated before, my car put down these numbers on a DYNO DAY. I didn't have access to more than 3 pulls. I was planning on up-ing the boost but didn't because I wanted to clean up the midrange fuel issue before anything else.
I know SR20s can handle more than 344/287...that is a walk in the park for these motors. Once I get my Intake Manifold & Equal Length made...450 can be attainable on a STOCK BOTTOM END
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Is that on the stock turbo?</TD></TR></TABLE>
Nope. T3/TO4E. The stock T25 turbo chokes around 260-270 WHP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KwikEG &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers manny!!! definitely repping for your nissan crew! looking good.
this is EcKo from iSM</TD></TR></TABLE>
Thanks a lot EcKo
Old Jan 28, 2005 | 03:24 PM
nonvtecD's Avatar
Any pics of the car? That thing must haul, very nice.
Old Jan 28, 2005 | 04:25 PM
Triscuit's Avatar
Default Re: (D15B7turbo)
I was about to say I knew it couldnt be a stock motor. What size turbo are you running? or better yet post your setup that would help...................
Aludew5
Honda S2000
24
Nov 15, 2007 08:49 PM
mac_24_seven
17
Oct 19, 2007 03:51 PM
prostreetonline
Honda Civic (2006 - 2015)
19
Apr 2, 2007 11:59 AM
SMSP
Acura TSX
15
May 9, 2006 03:50 PM
B18CXr
Apr 17, 2005 07:15 PM
