Stock Map sensor and 3 bar map sensor
Old Jul 9, 2006 | 12:01 PM
beak's Avatar
Default Stock Map sensor and 3 bar map sensor
I have a stock map sensor, and I'm trying to start my car, but the car has a Hondata S200B with a 3 bar map sensor map. It doesn't seem to want to run, and I was told I'd need to either get the Hondata recalibrated for the stock map sensor, or wire in a 3 bar.
I thought the stock map sensor read 0-11, and the 3 bar read 0-30. If this is the case, shouldn't the stock map sensor run fine just to fire up the car, and have it idle, even though the Hondata is set for 3 bar?
Thanks!
Old Jul 9, 2006 | 12:07 PM
ladysman's Avatar
Default Re: Stock Map sensor and 3 bar map sensor (beak)
You need to have the map calibrated for whatever sensor you are running.
It doesn't work like you said.
Old Jul 9, 2006 | 12:14 PM
beak's Avatar
Default Re: Stock Map sensor and 3 bar map sensor (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">You need to have the map calibrated for whatever sensor you are running.
Just curious why? It reads a different way?
Old Jul 9, 2006 | 01:02 PM
beak's Avatar
I have the Hondata software... can I disable the 3 bar map sensor, and go back to stock with the software, or does it have to be reprogrammed?
Old Jul 9, 2006 | 01:06 PM
adseguy's Avatar
Default Re: (beak)
No. The voltages are scaled differently so while the stock map says say 3 volts at 5 PSI the 3 bar will so 1.8 volts and 5PSI. That's why it won't work. You HAVE to get a new chip burned or plug in the 3 bar
Old Jul 9, 2006 | 01:28 PM
beak's Avatar
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">No. The voltages are scaled differently so while the stock map says say 3 volts at 5 PSI the 3 bar will so 1.8 volts and 5PSI. That's why it won't work. You HAVE to get a new chip burned or plug in the 3 bar</TD></TR></TABLE>
Thanks... I'll just break down and spend the $30 on a 3 bar
11psiGSR
Jul 5, 2023 09:36 PM
ForceFed Motorsports
Mar 7, 2008 03:57 PM
SpoolnByYou
Dec 24, 2005 02:35 PM
null.
Dec 15, 2005 06:35 PM
b16 matt
Sep 21, 2004 07:00 AM
