stock ls rods
Old Oct 25, 2006 | 04:07 PM
lakai_19's Avatar
Default stock ls rods
what are stock ls rods able to handle for revs wiht proper tuning i was thinking of taking them to 7500 and redline is like 6800 revlimiter is 7200 was thinking of changing revlimiter to 7500
bad idea? boosted of course
Old Oct 25, 2006 | 10:05 PM
champLSinteg's Avatar
Default Re: stock ls rods (lakai_19)
ive taken them to 8200 plenty of times when it was stock and even now that its boosted. i dont have arp rod bolts either. I shouldnt really take it that high but I do.
Old Oct 25, 2006 | 10:11 PM
SOHC_me's Avatar
i hear its useless unless you have power up there
Old Oct 26, 2006 | 06:51 AM
lakai_19's Avatar
well i got a big turbo sc61 and wont hit full boost till high rpm so what to go as high as i can
Old Oct 26, 2006 | 07:13 AM
JDMisGOOD's Avatar
Default Re: (lakai_19)
I've taken shot peened,arp equipped LS rods to 9500
However an SC61 should not be used in conjunction with stock internals...
Old Oct 26, 2006 | 08:26 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakai_19 &raquo;</TD></TR><TR><TD CLASS="quote">well i got a big turbo sc61 and wont hit full boost till high rpm so what to go as high as i can </TD></TR></TABLE>
That doesn't mean you will make any power up there. All the LS cars I've tuned (and you can look at other dyno graphs) show that the LS head and Intake manifold starts to drops off RAPIDLY after 6,500rpm. It doesn't matter even if you have great rods and pistons and a built bottom end. If the head is left untouched then the rev limit of 6,800 is the perfect shift point for best power. I've noticed a tad higher like 7,000 works as well.
Old Oct 26, 2006 | 01:20 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
That doesn't mean you will make any power up there. All the LS cars I've tuned (and you can look at other dyno graphs) show that the LS head and Intake manifold starts to drops off RAPIDLY after 6,500rpm. It doesn't matter even if you have great rods and pistons and a built bottom end. If the head is left untouched then the rev limit of 6,800 is the perfect shift point for best power. I've noticed a tad higher like 7,000 works as well.</TD></TR></TABLE>
tru but that was not the case on my LS granted this wanst a stock bottom end.. 85mm with a 62-1.. i was taking this motor to 7800 with the stock head w/blox IM
Old Oct 26, 2006 | 04:15 PM
adseguy's Avatar
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">
w/blox IM</TD></TR></TABLE>
That'll help considerably. Were you actually making power up that high though? Did you dyno it?
Old Oct 26, 2006 | 04:48 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
That'll help considerably. Were you actually making power up that high though? Did you dyno it?</TD></TR></TABLE>
yes i was.... and it was on a dyno but dont have the graph...
i guess a 85mm with a 62-1 helps a lil
vtec4max
Dec 28, 2006 09:08 AM
Flexin5
Mar 1, 2006 07:54 PM
89 pos
Apr 12, 2005 06:05 PM
94B18B1Teg
Feb 9, 2004 11:46 PM
