Stock LS at 17 psi.
Old Sep 29, 2007 | 10:09 AM
1g's Avatar
1g
Default Stock LS at 17 psi.
finished up the new turbo set up on the car ran a few new lines and took it out for a spin, built boost awsome in 2nd shifted when tires started spinning at around 5500 rpm and didnt watch the boost, hit third, got into it a bit more and the tires started spinning again and the tach jumped up of course, i glance away from the boost gauge to look at the tach. my eyes dart back to the boost gauge and its creeping just over 15 by now. then BANG!
feering the worst i clutch in and the car dies. it was all downhill to my house so i just coasted. get out and look for holes and broken bits and nothing. come today i go to look at it again, no visible damage so i decided for ***** and giggles to start the car. starts and idles fine, but with a bit of a white smoke and one mangled *** headgasket. then comes the thought, why in the expletive didnt my wastegate open? i go over everything, i mean everything and it all checks out, go to run a vacuum pump on the top port of the wastegate to check the spring and the damn thing wont open, run it up to 50 psi of vacuum and still nothing, of course by now the vacuum line was crushed but only half way. the stupid vacuum line was solid half way down. so choked. a 2 dollar part almost cost me a motor.
cliff notes:
new manifold and downpipe and a few misc. lines
take it for a drive
boost the **** out of it
destroy headgasket
never putting vacuum line on a motor without checking it again.
Old Sep 29, 2007 | 10:11 AM
90dxhmt's Avatar
Default Re: Stock LS at 17 psi. (1g)
What port of the wastegate were you hooked up to?I zip tie every vacum connection and always install new silicone vacum hose.Sucks to hear that time to build a motor
Old Sep 29, 2007 | 10:12 AM
97grnrs's Avatar
i ran 19 psi on my stock ls with a td05h eclipse turbo daily and it never broke once..
Old Sep 29, 2007 | 10:18 AM
90dxhmt's Avatar
Default Re: Stock LS at 17 psi. (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i ran 19 psi on my stock ls with a td05h eclipse turbo daily and it never broke once.. </TD></TR></TABLE>
Lol that turbo is so small it could be on a key chain
Old Sep 29, 2007 | 10:26 AM
alterdcreations's Avatar
Default Re: Stock LS at 17 psi. (90dxhmt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dxhmt &raquo;</TD></TR><TR><TD CLASS="quote">
Lol that turbo is so small it could be on a key chain </TD></TR></TABLE>
lol
Old Sep 29, 2007 | 12:19 PM
97grnrs's Avatar
Default Re: Stock LS at 17 psi. (alterdcreations)
ran 12.7 on a home made setup with that small turbo so i dont care.. most ppl aint runing that with their so called " name brand" kits they pay like crazy for so it worked for me. . i sold that car anyway
Old Sep 29, 2007 | 12:24 PM
BOOSTEd2's Avatar
you ran 12.7 cause your in a tiny *** crx
Old Sep 29, 2007 | 01:37 PM
95teilhatch's Avatar
do u have a dyno sheet with that set-up?
Old Sep 29, 2007 | 03:36 PM
97grnrs's Avatar
Default Re: Stock LS at 17 psi. (95teilhatch)
no .. my one crx ran 12's also but i ran the 12.7 in a 91 hatch..
Old Sep 29, 2007 | 04:17 PM
BOOSTEd2's Avatar
91 hatches just as light.
ldanphanl
Aug 23, 2005 05:31 PM
GraphiteAccord
Jun 28, 2003 02:02 PM
KooK
Nov 16, 2002 09:50 PM
clean
Aug 14, 2002 06:22 PM
