Stock d15 OVERBOOST PROBLEM 16+PSI ! ?HELP?
I can't belive...
All stock s..t I was sure you're plaing....
on mine setup The top of wg is connected to vacuum manifold after throttle body.
U can fine tune your setup by using micro air valves for controlling boost, with my setup wg works like push-pull with boost vacuum on intake manifold
Put a ic on car, replace clutch,injector, fuel rail , pump, upgrade ecu.
I think u must do this before selling the car... Nobody will buy in that condition
Mine are only suggestions
connect ur turbo directly on th body without anything no Wg no bov!!!!!!!!!!!!!!!!!!
What will happen?
The same ur are running ...Boooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooommmmmmmmmmmmmmmm
What will happen?
Sport_Injected
Aug 29, 2004 04:28 PM
