Stock B16 boost
Old Mar 9, 2006 | 06:47 PM
93first1's Avatar
Default Stock B16 boost
What amount of boost will a B16 handle prior to failure. One of the guys at a local shop told me that if I put 10 lbs on a stock set up it wouldn't last a month. What do you think.
Old Mar 9, 2006 | 06:52 PM
T3T495GSR's Avatar
Default Re: Stock B16 boost (93first1)
It would last a fair amount of time , depending on your tune. It isnt about the PSI, its about the HP. I dont see why you cant run about 260whp reliably on a stock si
Old Mar 9, 2006 | 06:56 PM
93first1's Avatar
What would that equate to as far as boost goes. I was looking at a T3/4 turbo with an intercooler and meth inject.
Old Mar 9, 2006 | 07:10 PM
greenbee's Avatar
if you're really worried about longevity build the head. a head that flows better will net more power at the same boost level compare to a stock piece (all other things equal). so lets say a stock si needs 14 psi to achieve 269 bhp at xxxx rpm. well you RLZ head may only 8-10 psi to achieve said bhp
Old Mar 9, 2006 | 07:51 PM
22psicrx's Avatar
I run 11 psi 18g in my race crx, trap speed 112mph. Motor has 10.4 comp stock everything. I raced a total of 15 times. As long as the air fuel ratio and timming are good it should last a while. Just did a compression check 210 210 210 210 . Go to NJ on the 19 of march.
Old Mar 9, 2006 | 07:53 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93first1 &raquo;</TD></TR><TR><TD CLASS="quote">What amount of boost will a B16 handle prior to failure. One of the guys at a local shop told me that if I put 10 lbs on a stock set up it wouldn't last a month. What do you think.</TD></TR></TABLE>
Well first of all I would suggest that you don't take your car to that place for tuning. Secondly many, many people are making 300whp+ on completely stock blocks and seem to not be having much problems. My guess (and only a guess) is that @ 10 psi you would be running somewhere between 270-310ish whp. This is of course very tune and setup dependant. If you want more specific answers you will have to give more specifics about your turbo setup including dp/exhaust/turbo mani/turbo ect....
honda_mike
Oct 29, 2008 10:46 AM
G0TB00ST
17
Mar 22, 2007 05:32 AM
carboy247
Jun 15, 2005 08:22 PM
str8boost
Mar 28, 2005 11:28 AM
projectTeG
Nov 7, 2003 06:56 PM
