stock b16 350+ possible?
Old Jul 1, 2010 | 08:35 AM
free99's Avatar
Default stock b16 350+ possible?
So I came across a b16a2 with 80k and I been itching for boost !
Here are my plans hp goals are 350+
Set up would consist of :
Bone stock b16a
Inlinepro log mani cast ( or suggest plz)
Garrett T3/T4E, 60 trim compressor, T3, 4 Bolt (2.5")
750 or 1000 injectors
255 walbro fuel pump
38mm tail wg
S300
Ebay piping and possibly D-pipe 3”
E85 !!
Do you think I’m shooting to high ? what would you do different to reach my goals ?
Old Jul 1, 2010 | 08:58 AM
joe111599's Avatar
Default Re: stock b16 350+ possible?
350whp is definitely within reach. Just get it tuned and you are good.
Old Jul 1, 2010 | 10:31 AM
free99's Avatar
i plan on tuning it in TX by tony palo shop T1racing. i want to get the most out of this motor with out braking my bank! i have e85 station a few blocks from my house that wont be an issue plenty of e85 in OKC
Old Jul 1, 2010 | 12:59 PM
LuczOr's Avatar
350 seems a bit high for stock b16, not that I have any experience. My gut just tells me that if you double the horsepower on a stock motor, it wont last very long.
Old Jul 1, 2010 | 02:24 PM
joe111599's Avatar
Wrong...if tuned properly then it will last. I had a stock gsr running 400whp for over a year before I finally built it and turned the boost on up. If Tony is tuning it then you will be fine. Bottom line.
Old Jul 1, 2010 | 03:18 PM
LuczOr's Avatar
Well dang, maybe I will shoot for 300 as well... I was scared to go over 250 on a stock b16a. Mine is freshly rebuilt too.
Old Jul 1, 2010 | 04:21 PM
AK94GSR's Avatar
at least put in some arp headstuds. i had a stock b16a2 with studs. put down 306 at 10lbs. on 450dsm injector. tuned by joe at locash. he said there was still some left in it put i was only goin off gate spring pressure
Old Jul 1, 2010 | 04:37 PM
N1 Andy's Avatar
R.I.P. Andy
THIS
350 on e85 will be more then fine. Especially with Tony tuning it. It will run for years and years. I'd go with at least 750cc's though, e85 requires 30% more fuel. The head stud suggestion is a good one too, do them one by one and you shouldn't have to even pull the head off.
Old Jul 1, 2010 | 09:42 PM
Speed_1's Avatar
Don't forget a clutch that will hold if you havent gotten one yet.
Old Jul 2, 2010 | 03:55 AM
SAXON's Avatar
that manifold will hold you back compared to a ramhorn manifold
especially with that turbo and a b16 you need a really efficient setup to get 350
Old Jul 2, 2010 | 07:56 AM
joe111599's Avatar
The manifold will work fine for 350whp. There are plenty 400+whp setups running log manifolds. I know they aren't the best but they get the job done. I mean if you have the extra cash to fork out then by all means get a ramhorn or at least a mini-ram. If not then just stick with the log for now.
Old Jul 2, 2010 | 12:30 PM
SAXON's Avatar
have you had a log manifold with a 60 trim on a b16? I have and let me tell you it wasnt easy to make 350, let alone with stock pistons etc
any thing you can do to make it more efficient will also help with making it last longer
Old Jul 2, 2010 | 09:01 PM
LuczOr's Avatar
Yeah, and ramhorn manifold looks way cooler anyway! Save up a bit!
Old Jul 2, 2010 | 09:41 PM
1FASTHF's Avatar
I made 312hp at 10psi on 91 octane years back on an ancient zdyne ecu.ran good for a year until the wastegate seized up...
Old Jul 2, 2010 | 10:04 PM
blackmugensivic's Avatar
My buddy put down 355whp @ 14psi on a bone stock B16A2 with headstuds, 450cc DSM injectors, walbro pump
Old Jul 3, 2010 | 07:02 AM
Civic89stdB16's Avatar
ur good to go with the 350whp goal on the e85. u should get the 750s or even get 880s. Its will be a blast. Just blew my b16 on 19psi with a walbro, aem regulator and 450s on 93 pump. its was great while it lasted. now im building a motor and going e85 with 1200cc injectors and a goal of 450whp and a 10 sec time slip. good luck with ur build.
Old Jul 3, 2010 | 07:05 AM
joe111599's Avatar
Its been done SEVERAL times. Log mani and 57 trim. Dont know what your problem was there bud. lol
And stock pistons??? Whats the problem? People have made 500whp on stock pistons. Like I said...its all in the tuning.
Old Jul 4, 2010 | 03:49 AM
SAXON's Avatar
i never said it couldnt be done, just stating it can be done alot more efficiently with a better manifold
more efficient= better all around
Old Jul 4, 2010 | 07:40 AM
joe111599's Avatar
I agree.
xchipx
Mar 13, 2010 06:55 PM
blasterman87
Dec 29, 2009 01:18 PM
wfocrx
Apr 16, 2007 01:35 PM
Willie
Oct 22, 2006 06:10 AM
markvqwerty
Jan 8, 2005 01:21 PM
