Still having boost problems(profec B)
Old Feb 16, 2004 | 03:35 PM
ATS*Mark's Avatar
OG triple OG
Default Still having boost problems(profec B)
ok guys im still having problems getting my car to hold steady boost. what should i look for??? ive checked the piping and it seems to be good. could it be the bov?
boost will go up to lets say 8.5 lbs , then go down to like 7.9 right away , then slowly creep down to like 7.4 , i dont get why it wont hold boost , is it my boost controller?
Old Feb 16, 2004 | 03:44 PM
Jared's Avatar
Default Re: Still having boost problems(profec B) (Hella_JDM)
have you tried adjusting the gain? what about the dip switches on the back?
Old Feb 16, 2004 | 04:41 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Still having boost problems(profec B) (Jared)
ok i just got back from fiddling with it , i took off the boost controller vacume lines ,and put it back to stock boost. and it held boost at 5.5 like its supposed to , so i can rule out a boost leak.
what do the things on the back do? and i have tried everything on the boost controller to get it to hold boost and it just fluctuates.
gain cant be set higher than the target boost pressure % right?
Old Feb 16, 2004 | 04:42 PM
Jared's Avatar
did you try reading the manual? it explains all that.
Old Feb 16, 2004 | 04:55 PM
lilgimpy03's Avatar
i have that boost controller
turn the gain DOWN, mine hold boost perfect
Old Feb 16, 2004 | 05:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Still having boost problems(profec B) (lilgimpy03)
but the boost is falling off , meaning the gain should go up!
Old Feb 16, 2004 | 05:18 PM
ATS*Mark's Avatar
OG triple OG
i dont think mine had those little switches on the back , its a profec b 2
Old Feb 16, 2004 | 05:28 PM
I Like Boost's Avatar
for the regular profec B in the directions when its says your overboosting on a external wastegate to change the settings on the back to......
4 3 2 1
edit - you have a spec 2 ...... oh well i dont know **** about those
Old Feb 16, 2004 | 05:58 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Still having boost problems(profec B) (I Like Boost)
ya i dont see anything like that in the spec 2 manual
Old Feb 16, 2004 | 07:08 PM
ATS*Mark's Avatar
OG triple OG
bump
Old Feb 16, 2004 | 08:04 PM
ATS*Mark's Avatar
OG triple OG
bump can anyone help
Old Feb 16, 2004 | 08:30 PM
B18bEK's Avatar
man i had the same problem but with the reg. profec B, i just switched to the turbo xs mbc and it solved all my problems
Old Feb 16, 2004 | 10:15 PM
accordfreak's Avatar
bump cuz i'm wondering the same.
Old Feb 17, 2004 | 01:37 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Still having boost problems(profec B) (accordfreak)
ya i might just turn my wastegate actuator up man and **** the ebc....
Old Feb 17, 2004 | 04:19 AM
mildly.interesting's Avatar
you need to put the set gain about 2 lbs lower than whatever you want to boost to, that stops if for fluctuating the wastegate to try and compensate for the pressure drop. You need the gain around 20%, and adjust with set, not gain. If this isn't your problem then you have it hooked up wrong.
I have a 9 lb spring in my Tial, and make 12-13 on low boost and 16-17 on high boost. I can't remember what the high boost settings are, but low boost is 19% set, 20% gain, and set gain is 105. Remember this is all in lbs, not bar, because I'm a US citizen, and refuse the ******* metric system (haha)
Old Feb 17, 2004 | 05:35 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (mildly interesting)
start gain is 105???? are we talking about the brofec b ll here?
Old Feb 17, 2004 | 05:51 AM
Default Re: (Hella_JDM)
sorry man, maybe I meant set gain....its whatever is after the gain setting when you're pushing the mode button...dude, you got the same manual I did, read that bastard for about 3 days, and the Engrish becomes your second language...remember set gain is in lbs, not percent like the rest of that **** is...
Old Feb 17, 2004 | 02:36 PM
ATS*Mark's Avatar
OG triple OG
see that i didnt know , i read it , but i guess not good enough. ovbiously hehehe
Old Feb 17, 2004 | 05:22 PM
sorry but can you guys explain what the does start gain, set, and set gain function as?
Old Feb 17, 2004 | 05:34 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (accordfreak)
ok im playing with it and im starting to get it.....im just trying to tune for 8 lbs
so i set the set gain to like 6 , then gain to 20% , then like 15 for the pressure. still cant get it fine tuned i dont know which way to go with it
Old Feb 17, 2004 | 06:46 PM
keep adjusting man, a little bit at a time....how big of a spring do you have...in lbs, I don't deal with that bar ****...
Old Feb 17, 2004 | 07:02 PM
ATS*Mark's Avatar
OG triple OG
ya i dont talk in bar either **** that crap , its an internal wasegate at 5.5 lbs......
so i set my gain to 20% , and set gain to 6 lbs cause i want 8 lbs , then adjust with the pressure right? the one where you just turn the **** , you dont press mode to get to.
Old Feb 18, 2004 | 03:29 AM
right on man
Old Feb 18, 2004 | 03:43 AM
ATS*Mark's Avatar
OG triple OG
thanks man i appreciate it , i had this thing so fucked up and backwards in my head..... i thought set boost was in % just like the others , i thought the pressure setting was what you wanted your boost to be at , and i didnt think you could set gain higher than the pressure.....i was all fucked up
Old Feb 18, 2004 | 08:57 AM
another thing you might want to watch is raising the gain, it helps hold boost steady, but too much will make it spike...
