Still Burning Oil....
Old Oct 23, 2002 | 06:52 AM
Projekt20's Avatar
Default Still Burning Oil....
Even after the rebuild I'm still burning oil, but I don't think it's my rings. I checked my plugs and I have oil on the bottom portion of the plugs, where the threads are. Bad valve seals? Car doesn't smoke at idle only at full throttle @ high RPMs. Any ideas? Thanks.
-Trung
Old Oct 23, 2002 | 07:30 AM
Speed PHreak's Avatar
Default Re: Still Burning Oil.... (Projekt20)
2 questions:
How many miles on your rebuild?
Does it smoke on startup, but then quit?
Old Oct 23, 2002 | 08:26 AM
1.8T_EG's Avatar
Default Re: Still Burning Oil.... (Speed PHreak)
bump (cuz i have the same prob)
Old Oct 23, 2002 | 10:16 AM
filetofit
Guest
Posts: n/a
Ringlands
Got any compression numbers for us?
[Modified by filetofit, 7:16 PM 10/23/2002]
Old Oct 23, 2002 | 10:56 AM
Projekt20's Avatar
1. 1780 miles now
2. At initial startup it does smoke a lil....but it'll be ok for the rest of the day.
Rebuild is still NA and I just started using 5w30 Mobil 1 synthetic. I know with the lighter oil it's gonna burn quicker....but I had 10w30 Castrol GTX for the break in and around 900 miles I found the oil on the plugs and lost about 1-1 1/2 a quart from 0miles to 600miles. I'll get some compression numbers later on tonight if I can. If it helps any, motor was rebuilt with GE sleeves and JE pistons and rings. Thanks
-Trung
Old Oct 23, 2002 | 12:10 PM
1.8T_EG's Avatar
OT... but Projekt20, what size bore did you go with as far as your GE sleeves?... i am planning on sleeving my block this winter and have been told conflicting info... some say stock bore... some say 84.5mm... lemme know... thanks...
Old Oct 23, 2002 | 12:29 PM
Sounds to me like you've got yourself a case of bad valve seals. Do a compression test. and see what kinda numbers you come up with. I'll bet your breakin is just fine.
I'd say just pull the head and have a basic valve job done to it and you ought to be back in business.
Old Oct 23, 2002 | 04:44 PM
Projekt20's Avatar
Default Re: Still Burning Oil.... (1.8T_EG)
I only had mine done to 81.5mm figure I might wanna go over more later on.
-Trung
Old Oct 23, 2002 | 05:15 PM
speedworks's Avatar
je rings are really hard to seat. hondas usually do not have problems with there valve seals. you need to run a cylinder leakdown test
Old Oct 23, 2002 | 06:12 PM
WONG FRIED RICE's Avatar
what kind of piston rings did you use? when u did rebuild...did you bore cylindar walls? if not...that could be the problem. Je piston rings don't seal to good. Especially if when u did the rebuild, and u didn't do a little boring. Maybe invest in a set of total seal piston rings? I heard very good things about those.
Old Oct 23, 2002 | 09:45 PM
Projekt20's Avatar
Default Re: Still Burning Oil.... (JDMB16ACRX)
Actually I've heard it the other way around.....that Total Seal Rings suck. I dunno....I'm gonna do a comp. test this weekend and give you guys an update. Thanks.
-Trung
Old Oct 24, 2002 | 03:31 AM
speedworks's Avatar
total seals are total ****. been there,done that
Ci-v-iC
Aug 13, 2011 11:17 AM
Swapped94
Jan 12, 2009 04:54 PM
Powelly
12
Sep 5, 2008 09:54 AM
veilsides2000
Apr 9, 2006 10:08 AM
Sl0wEK
Dec 5, 2004 10:12 PM
