step deck vs o-ring
Old Nov 16, 2003 | 01:42 PM
Wo-Nelly's Avatar
Default step deck vs o-ring
Could some one tell me the difference? I want to have my block sleeved soon and I just want to know what I need to do. I'll also be wanting to bore out the cyclinders 2mm, this is for a H22 so from 87mm to 89mm. What kind headgasket would I be looking for?
Old Nov 16, 2003 | 04:39 PM
Wo-Nelly's Avatar
Default Re: step deck vs o-ring (GottaLude)
up pls
Old Nov 16, 2003 | 04:53 PM
Rhman19's Avatar
A step deck block is when the sleeve is a little bit higher to seal better. An o-ring is a little copper ring on top of the sleeve that also helps sealing. Which one is better depends on who you talk to, I don't have first hand experiance with them, so I won't recommend which is better. I hope that explains the difference between the two.
08zx14
Dec 22, 2009 07:49 PM
RacinMasonC
Feb 10, 2008 02:28 PM
h22silvia
Apr 17, 2007 02:54 PM
integraboosted
Oct 22, 2006 06:22 AM
civexturbo
Nov 4, 2005 01:29 PM
