Stats of IHI VF10 turbo on B16A2
Hi, would somebody be able to provide some information about a IHI VF10 turbo, I currently have one but am not sure how well it would run on my B16A2, what boost does it run standard and how efficient would it be at 7-10psi, would it run good on my engine without maxing out, will be pull strong till bout 8krpm
Thanks
Thanks
Re: Stats of IHI VF10 turbo on B16A2 (WEPN R)
About 7- 8 psi is there standard boost, you get it off a auto subaru? I would get the vf8 off the manual version if I was you bit bigger, be more effective at 10psi, but having said that I imagine it would be still pretty efficient, I have the vf8 on my little sohc no problems its a good size.
Re: Stats of IHI VF10 turbo on B16A2 (turbozxi)
I was told that the VF10 was slightly bigger, but not 100%, have you seen them side by side?, anyway anithing bigger will be hard fitting as i plan on retaining the a/c. Hows your car running turbozxi, at 200whp it must be pretty rapid and fun to have a blast around on
danielm3
Welding / Fabrication
33
07-05-2008 07:42 AM
