Stand Alone Users And Tuners, ....Question????
Old Feb 1, 2003 | 12:35 PM
turbo Si's Avatar
Default Stand Alone Users And Tuners, ....Question????
I'm running the DFI Gen 7. My timing was initally set at 24 degrees. I recently have been playing with the fuel and timing. I have added timing to as much as 34 degrees in some points and it feels stronger and AF is 12.2 constant at WOT on 7-8 lbs of boost. Might I add this is on Weisco 8.8:1 compressionin a B16A2. A friend of mine who runs Speed Pro on his stock B16 10.2:1 (I believe) compression and his timing was set no higher than 28 degrees under boost areas. I am getting it tuned soon although felt the urge to play with it. What area of timing under boost do ya'll think is relevant under boost for this setup?
Old Feb 1, 2003 | 12:59 PM
VaporTrail's Avatar
New User
Default Re: Stand Alone Users And Tuners, ....Question???? (turbo Si)
you really shouldnt be doing ignition tuning on the street, that should be done on the dyno. Your twin cheek dynometer will not tell you everything you need to know or what a real dyno will show you. I normally wouldnt exceed 28 degrees or so, load is usually higher on the street and you might encounter detonation from too much advance, even with perfect a/f.
Old Feb 1, 2003 | 01:02 PM
Quick 200k Mile Motor's Avatar
Default Re: Stand Alone Users And Tuners, ....Question???? (VaporTrail)
VaporTrail, do you recommend J&S>?
Old Feb 1, 2003 | 01:13 PM
VaporTrail's Avatar
New User
Default Re: Stand Alone Users And Tuners, ....Question???? (Quick 200k Mile Motor)
I could see it's uses in some people's views, but I have never seen an instance where one would have saved a motor. A properly tuned motor shouldn't detonate, and should you have a failure, like fuel pressure or something of that nature, retarding the timing isn't going to do much, if anything, to save your motor. I guess I'm old school, I don't like too many boxes controlling too many things.
Old Feb 1, 2003 | 01:25 PM
BudaKai's Avatar
Too many boxes = Too many thing to go wrong =Too many wiring mistakes = Waaay too many blown motors.
Hey these kids will learn one of these days. Electronic fail when you least expect it. Especially if an amatuer installs them. No offense intended, but it's true. I've seen too many kids leave the scene because they didn't wie stuff up correctly, and got a ll pissed up at the problems they were having.
Old Feb 1, 2003 | 01:34 PM
VaporTrail's Avatar
New User
Default Re: Stand Alone Users And Tuners, ....Question???? (tzsir)
couldnt have said it better myself
Old Feb 1, 2003 | 02:52 PM
I wonder if Hondata can datalog knock, and if that is recommend to get the timing.
[Modified by Quick 200k Mile Motor, 6:53 PM 2/1/2003]
Old Feb 1, 2003 | 03:59 PM
turbo Si's Avatar
I see........we'll I guess it's in my best intrest to upload the original program my tuner setup for me to drive around in.
Thank's.
ghost14
Engine Management and Tuning
Sep 18, 2012 11:30 AM
turbo boost
Oct 19, 2007 01:57 PM
all_out_jdm
May 21, 2005 04:23 AM
ID_ten_T
Jan 20, 2004 07:11 PM
echo999
Dec 31, 2002 11:28 AM
