stainless valves...?
Old Aug 14, 2002 | 02:15 PM
simple4012's Avatar
New User
Default stainless valves...?
Should i do stainless avlves for my turbo setup?
looking to make 500 HP at max on race gas.
Most likely only around 400-440 on pump...
Old Aug 14, 2002 | 03:11 PM
ninesecrx's Avatar
Default Re: stainless valves...? (simple4012)
You should get them. Its real easy to burn a valve making big hp....stainless with help prevent that.
Old Aug 15, 2002 | 01:47 AM
mskibbz-T's Avatar
Default Re: stainless valves...? (ninesecrx)
What about milder setups like 250whp on a B18B 10:1 at around 8 PSI? Was thinking of getting Ferrea SS valves put in when I build my bottom end in a couple of weeks... Thanks
Old Aug 15, 2002 | 02:06 AM
ninesecrx's Avatar
Default Re: stainless valves...? (mskibbz)
If your gonna build your bottom end, ill assume your wanting more then 250hp and more then 8 pounds. If so....they are always a good idea along with stiffer springs and retainers.
Old Aug 15, 2002 | 08:03 AM
DSF's Avatar
DSF
Compared to Ferrea, how is the quality of Si, Manley, Skunk2...?
Just checking my options, since I'll be buying shortly
Old Aug 15, 2002 | 09:27 AM
rtype11's Avatar
if money is a concern get only exhaust side valves, but have all cut atleast 3 angle.
The stock intake are very good and ame weight so no real difference. If you are going oversize then gorget all of this.
Old Aug 15, 2002 | 09:50 AM
DSF's Avatar
DSF
Default Re: stainless valves...? (rtype11)
Money isn't a major concern. I just didn't want to spend x amount of dollars on brand Y and then find out brand Z is of equal quality, but costs less. Make cents
edit: Oh and I'm staying with the stock size. At the moment the head has ITR intake valves, so I may or may not replace them since they are fairly new. (Probably will end up doing the intake side in the long run.)
[Modified by DSF, 1:54 PM 8/15/2002]
Old Aug 15, 2002 | 10:32 AM
dustin's Avatar
hehe good luck
slowtegkauai
Apr 12, 2008 01:37 PM
MysteriousGSR
Mar 28, 2003 12:40 AM
Allstar
Apr 30, 2002 07:54 PM
Smoothy
Sep 23, 2001 05:38 PM
