Sputtering, Misfire, Die....Wierd
Old Aug 2, 2007 | 08:15 AM
Turbo-GSR1287's Avatar
Default Sputtering, Misfire, Die....Wierd
I did an extensive search and found many problems it could be....but nobody seemed to list same symptoms as my situation...so here goes..
Recently i installed a turbo kit (not sure if has anything to do with anything)..anyway i then within the last week or so converted my 94 GSR to an external coil (msd blaster 2). Car cranks up fine...annd drives like a beast...after a few times of boost and car really heats up under the hood it will start misfiring and almost sound like its not getting proper spark. Also on the occasion i start the car and let it idle for about 5 mins or so then try to drive it once i start to accelerate it will just choke on itself sputter and die. Then after it dies and i try to crank it i can here it trying to turn over but..nothing, I like have to wait for 10 minutes for it to cool off or something..(no its not overheating). Im not sure what this problem could be any thoughts...?
Old Aug 2, 2007 | 08:33 AM
Default Re: Sputtering, Misfire, Die....Wierd (Turbo-GSR1287)
anything....This problem is so spurratic and spontaneous its aggravating!
Old Aug 2, 2007 | 09:27 AM
bigbadboy's Avatar
are u tuned?? also have u tried removing the MSD stuff to see if thats the problem??
Old Aug 2, 2007 | 10:07 AM
GSROWNSU's Avatar
coolant temp sensor?? I had that go bad on a d-series once and it did the exact same thing. Became quite annoying when you stop to fill up with gas and you have wait 20 min before you can start the car back up lol
Old Aug 2, 2007 | 10:12 AM
SovXietday's Avatar
Default Re: (GSROWNSU)
Have you tried pulling the MSD stuff off and go back to stock?
Old Aug 2, 2007 | 11:07 AM
patrick4588's Avatar
my msd dizzy just took at **** on me and before it did, i had your symptoms.
Old Aug 2, 2007 | 01:15 PM
Default Re: (patrick4588)
Problem solved.....The external coil wire wasn't crimped properly.....so i guess it wasn't getting the proper spark to begin with.
But even though i fixed the wire i noticed when i hit full boost the car kinda falls on its face...if my spark plug gap is too wide could it cause this.....?
Old Aug 2, 2007 | 01:24 PM
what is your gap at? and what plugs are you running? i have mine gapped at .030 on ngk bkr7e's
Old Aug 2, 2007 | 03:03 PM
Stock plug gapped at .052 stock gap i think.......Can a gap this big cause it to be almost undrivable with misfires?
Old Aug 2, 2007 | 03:31 PM
yes!! lol. gap them down to .028 if you are running the stock distributor. and make sure you get plugs in the 7 heat range
Old Aug 2, 2007 | 04:17 PM
wow are you right......I gapped them down to .028 and sure enough start up and it was smooth as ever all the way to 8000. Although I have only 6's right now...i will definately be picking up a set of NGK 7's.. thx man.....just kinda curious....is there really that much difference between heat range 6 and 7. and is it detrimental to run 6's instead of 7's ?
Old Aug 3, 2007 | 09:42 PM
it will keep them from pre detonating. they are not any more expensive, just run the right heat range. ngk bkr7e. part #6097 i believe. like 2 bucks each. i always just buy 2 boxes of ten. depending how you drive your car, expect to change them fairly often. if you get on it at least once or twice every drive, probably once a month...
shadohconspiracy
25
Jan 20, 2023 12:34 PM
7andaswitchblade
May 26, 2009 08:10 PM
Turbo-GSR1287
Aug 2, 2007 10:18 PM
94lsboost
Oct 20, 2005 04:27 PM
Rain_man
Feb 10, 2003 01:52 PM
