sputtering at idle
Old Jun 9, 2005 | 08:19 AM
c61lude's Avatar
Default sputtering at idle
not sure if this is a big deal but my car keeps sputtering at idle. It will just kind of sputter sputter and maybe drop 50 rpms(not 500, just 50). nothing intense I was just thinking spark plugs. any ideas? a/f ratio at idle is 14.0 off my plx wideband, should I even worry about this?
Old Jun 9, 2005 | 09:42 AM
c61lude's Avatar
Default Re: sputtering at idle (c61lude)
bump it up
Old Jun 9, 2005 | 09:43 AM
ginoboy1978's Avatar
Are you turbo'd?
Do you have bigger injectors ?
Whats your setup?
Sputtering is prolly not a big deal.
DAN
Old Jun 9, 2005 | 10:09 AM
EJ1 wilcox's Avatar
Default Re: sputtering at idle (ginoboy1978)
Let's see...
I would first check your plugs, rotor, cap, and wires. If those look good, then do a compression test, uneven compression can cause a sputtering idle.
If your ignition components look good and you have good compression, then I wouldn't worry about it. Maybe pull a little fuel so you aren't idleing at 14.0 AFR.
What is your idle set to anyways?
Old Jun 9, 2005 | 10:39 AM
c61lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">Are you turbo'd?
Whats your setup?
DAN</TD></TR></TABLE>
yeah I'm turbo, injetors are 750cc's
walbro 255lph, golden eagle fuel rail, sx fpr on 50psi
aem pems 30-1020 tuned boost comp, closed loop
idle is set to 1500 r's
also I was under the impression a/f for idle should be 13.7
Modified by c61lude at 1:09 PM 6/9/2005
themorphious
Engine Management and Tuning
Mar 24, 2012 08:46 AM
hai_tech
19
Mar 20, 2007 07:26 PM
ilovejdmhoes23
Jan 27, 2007 08:39 AM
Chillinit
11
Oct 24, 2005 12:04 PM
