Which springed clutches can handle 400+ whp??
Pretty much like the title says. I'm looking for clutches with the springs in them that can handle at least 400 horsepower or more. I haven't been able to find which one would be best for my application. So, if you have any ideas as to which name brand clutches and types I should look into, please let me know. If you have a website, that would be great. Please post the link.
Thanks!
My Setup:
-- Turbo GSR
-- GSR tranny
300whp daily
Looking for 400+ at the track
Re: (b00stedeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedeg »</TD></TR><TR><TD CLASS="quote">im running the competition stage 5 sprung</TD></TR></TABLE>
I sell these to alot of customers with no issues BUT I usually put them into the upgraded Pressure plate Stage 5. I have had friends'customers make 550whp/375 ft-lb torque on these on a race car then a daily driven weekend warrior making 450whp
Re: (Boostfed.com)
Cool. Well, I didn't know what was a good brand and clutch to go with. I currently have the f/s 6 puck clutch kit with flywheel, NO SPRINGS. It lasted about 3 months.
The center spline of my clutch plate got stripped and in turn it also ended up stripping my shaft. So now I have to replace the shaft and bearings. I was recommended to probably get the Exedy 3 puck sprung hub clutch, which I was told can take over 400hp. Or if I really wanted to get hard core to go with something like a hyper single clutch but those cost about $1,200. I don't have that kind of money for a clutch right now.
Anywho, I'm eager to get my car back on the road.
Boosting is addicting, but I like it.
Re: (b00stedeg)
Guest
Posts: n/a
Re: (G-Phi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-Phi »</TD></TR><TR><TD CLASS="quote">Cool. Well, I didn't know what was a good brand and clutch to go with. I currently have the f/s 6 puck clutch kit with flywheel, NO SPRINGS. It lasted about 3 months.
for 1250 you could get a twin disc...lol. you can get a nice sprung 6 puck for petty cheap. maybe 500 or below i ould guess.
Re: (cuin9sec)
you really shouldnt be looking for clutches in terms of hp but in torque capacity, at 400whp you'll have something aorund 275-300ft/lbs. So look for a clutch/pressureplate with that torque capacity
Re: Which springed clutches can handle 400+ whp?? (G-Phi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-Phi »</TD></TR><TR><TD CLASS="quote">300whp daily
Looking for 400+ at the track</TD></TR></TABLE>
thats why lol
thats why lol
Re: (Boostfed.com)
I just cooked a Comp stage5 tuning a 84mm built LS/vtec.
The car made 350ft/lbs on a Dyno Dynamics (add at least 15% for dynojet figures) - and then the clutch slipped massively. Torque graph looked like a horseshoe. Lasted for about half a dozen pulls above 15psi before it cooked.
I didn't install it, I just tuned it. Can't say more than what happened
Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">I just cooked a Comp stage5 tuning a 84mm built LS/vtec.
I didn't install it, I just tuned it. Can't say more than what happened</TD></TR></TABLE>
Regular pressure plateor the HD or Dual Diaphragm pressure plate? With that power I only sell the upgraded pressure plates to customers , no issues from several customers so far
I've also cooked 2 ACT XTSS clutches on <350ft/lbs of torque (again, dyno dynamics numbers) in the past month. I personally think ACT is overpriced garbage for anything other than daily-driven weekend warrior cars that doen't make much power. THAT is very much a biased personal opinion, but I seem to shred altogether too many of their clutches under more serious power.
Re: (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Regular pressure plateor the HD or Dual Diaphragm pressure plate? With that power I only sell the upgraded pressure plates to customers , no issues from several customers so far </TD></TR></TABLE>
I'm not sure. Pedal pressure when driving the car on the dyno was certainly stiffer than stock but far from the Action 2MD, which is my point of comparison for a stiff clutch. As I said, I didn't buy it, I didn't install it, I don't know exactly.
Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">I've also cooked 2 ACT XTSS clutches on <350ft/lbs of torque (again, dyno dynamics numbers) in the past month. I personally think ACT is overpriced garbage for anything other than daily-driven weekend warrior cars that doen't make much power. THAT is very much a biased personal opinion, but I seem to shred altogether too many of their clutches under more serious power.</TD></TR></TABLE>
Not reassuring for someone running an ACT clutch, damn...
To the original poster, why so focused on a sprung hub? Unsprung is simpler (less parts to break), lighter, cheaper... and not much different to drive IMO. Just curious/suggesting I kind of prefer knowing that springs will never pop out of mine, and it's been daily driven in all sorts of conditions! Unsprung 6 puck is really not all that bad...
Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">Not reassuring for someone running an ACT clutch, damn...
To the original poster, why so focused on a sprung hub? Unsprung is simpler (less parts to break), lighter, cheaper... and not much different to drive IMO. Just curious/suggesting I kind of prefer knowing that springs will never pop out of mine, and it's been daily driven in all sorts of conditions! Unsprung 6 puck is really not all that bad... </TD></TR></TABLE>
Note: I haven't killed any XT PP / 6 puck combinations yet. I was referring mostly to the SS disc that everybody thinks is good for a DD turbocharged motor...
Re: (raene)
yes
Note: I haven't killed any XT PP / 6 puck combinations yet. I was referring mostly to the SS disc that everybody thinks is good for a DD turbocharged motor...</TD></TR></TABLE>
exactly, unsprung 6 puck is great, SS is generally overrated
yes
Re: (Bailhatch)
Well, the reason why I'm looking to get a sprung hub is because of my current situation with an unsprung clutch.
I had a 6 puck unsprung f/s cluthch kit w/flywheel put into my car. It lasted for about 2-3 months. The shaft stripped out the center spline of the clutch, which in turn grinded down my shaft... and the shaft was in good condition.
I don't want to have to replace my clutch and tranny shaft every 2-3 months. It ain't cheap. That's why I'm looking for a sprung hub. I need something that can handle 400+ hp. My car is a weekend warrior but a 300 hp daily driven car.
