spot welded ported shroud????
Old Mar 19, 2006 | 04:56 PM
boosted94cx's Avatar
* B A N N E D *
Default spot welded ported shroud????
anyone have any clues about this?
pic borrowed from a&c forum......don't ask why i was in there..cause i don't know
Old Mar 19, 2006 | 05:35 PM
Adi Radoncic's Avatar
On Fire!
Default Re: spot welded ported shroud???? (boosted94cx)
Hey please link me to that post, thanks!
Old Mar 19, 2006 | 05:37 PM
* B A N N E D *
Default Re: spot welded ported shroud???? (Adi Radoncic)
https://honda-tech.com/zerothread?id=1564026
Old Mar 20, 2006 | 10:16 AM
LilCivic04's Avatar
to me it looks like they cut part of the inlet if im correct
Old Mar 20, 2006 | 10:44 AM
JDM_Risa's Avatar
Default Re: spot welded ported shroud???? (LilCivic04)
are u sure thats ported shrouds...or just his own way of make the inlet bigger to accept a bigger size filter
Old Mar 20, 2006 | 11:06 AM
IHaveTurbos's Avatar
There is a velocity stack welded to the inside of the GT4088R this is a Full-Race built car and Geoffs GT40 is the same way.
Old Mar 20, 2006 | 12:10 PM
* B A N N E D *
Default Re: (TurboElements.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com &raquo;</TD></TR><TR><TD CLASS="quote">There is a velocity stack welded to the inside of the GT4088R this is a Full-Race built car and Geoffs GT40 is the same way. </TD></TR></TABLE>
what do you mean?
Old Mar 20, 2006 | 12:19 PM
this was posted on here awhile back.
Old Mar 20, 2006 | 12:21 PM
* B A N N E D *
so....they grind down part of the inlet and put that in place to match up to the wheel opening?
why? why not just choose a non-ported cover in the first place?
Old Mar 20, 2006 | 12:42 PM
Importordomestic's Avatar
Default Re: (boosted94cx)
interesting... subscribed to see how this turns out
Old Mar 20, 2006 | 12:51 PM
As far as I know they just have the velocity stack cut to fit without having to cut anything on the housing.
And there is no non-ported comp housing available for the GT4088R.
Old Mar 20, 2006 | 01:02 PM
* B A N N E D *
so...wonder why they didn't extend it out farther...away from the edge of the housing...won't this still create some turbulance?
Old Mar 20, 2006 | 02:20 PM
mrbsponge's Avatar
im not an engineer or something, but that little opening all around the velocity stack CANT be that great for performance, i mean if you wante to make full use of the stack, shouldnt it be sealed, or mated with the opening of the turbo???
just looks like an unfinished product or something
Old Mar 20, 2006 | 02:48 PM
Justin Olson's Avatar
Default Re: (mrbsponge)
The outer area around the stack needs to be open to take advantage of anti surge compressor housings. The velocity stack cuts down on turbulence, and helps the midrange a bit.
Old Mar 20, 2006 | 03:29 PM
JDM_Risa's Avatar
Default Re: (Justin Olson)
now i am super confuse...agreed looks like an unfinish product
Old Mar 20, 2006 | 03:44 PM
adictionbass's Avatar
Default Re: (JDM_Risa)
no air goes into the turbo on the outside of the velocity stack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">The outer area around the stack needs to be open to take advantage of anti surge compressor housings. The velocity stack cuts down on turbulence, and helps the midrange a bit. </TD></TR></TABLE>
Old Mar 20, 2006 | 03:48 PM
BodyKits NW's Avatar
Default Re: (adictionbass)
Hmmm that is pretty interesting. I wonder if there are any gains to be had by doing that. Are they manuf. the velocity stacks in house?
Old Mar 20, 2006 | 03:57 PM
* B A N N E D *
well there are NUMORUS post about non-ported housings making more power than ported....so i guess that's pretty much the goal of this...so, yeah...i think there might be some gains to be had. pretty cool stuff
Old Mar 20, 2006 | 04:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">the benefit from "deleting" it is not from the lack of the surge rung, the benefit comes from the fact that the air entering the compressor housing is a fully laminar flow, and its less of a pressure differential across the compressor wheel.</TD></TR></TABLE>
http://www.supraforums.com/for...87830
Old Apr 27, 2006 | 11:21 AM
Muckman's Avatar
Moderator in Chief
I believe this eliminates any downside to running a slotted anti-surge cover. Cuts down on air flow turbulance.
Old May 20, 2006 | 12:50 PM
GenIIIMrDuece's Avatar
Default Re: (Muckman)
hmm that is interesting.. now where could i find a velocity stack to fit my 42r
Old Aug 21, 2006 | 02:40 PM
Default Re: (GenIIIMrDuece)
I am going to resorect this thread to see if anyone knows were i can find this velocity stack for my 42r!!!!
Rene M
Jan 21, 2006 08:23 AM
jsk62
Oct 24, 2005 12:40 AM
Emshhh
Sep 13, 2004 06:33 PM
JDMek
Jun 4, 2004 12:15 AM
bdb
Oct 29, 2003 03:06 PM
