Spoolins Quick4 Manifold Oil Return
Old Nov 3, 2006 | 03:42 AM
mrchris1979's Avatar
Default Spoolins Quick4 Manifold Oil Return
Modified by mrchris1979 at 1:13 PM 1/11/2007
Old Nov 3, 2006 | 03:50 AM
g2turbo's Avatar
Default Re: Spoolins Quick4 Manifold Oil Return (mrchris1979)
I have the lovefab version of this manifold...Ill post up pics later of how we did my line.
Old Nov 3, 2006 | 04:01 AM
Default Re: Spoolins Quick4 Manifold Oil Return (g2turbo)
Great Thanks
Old Nov 3, 2006 | 04:28 AM
Autoworks's Avatar
Mine looked just like yours...Innovative baar and all.
I just got a newer version of the mani that should sit the turbo a little higher.
I'll get some pics up
Old Nov 3, 2006 | 04:42 AM
Default Re: Spoolins Quick4 Manifold Oil Return (Autoworks)
So was this manifold re-designed due to the turbo being too low? Might have to check with Spoolin on this one.
Old Nov 3, 2006 | 05:53 AM
GrinderGuy2's Avatar
something similiar to yours.. I had to clock it so i could use a 45degree fitting going straight down. then a 90 degree an fitting straight to the Pan
Modified by GrinderGuy at 8:53 AM 11/3/2006
Old Nov 3, 2006 | 06:28 AM
drintegra's Avatar
Default Re: Spoolins Quick4 Manifold Oil Return (GrinderGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrinderGuy &raquo;</TD></TR><TR><TD CLASS="quote">
something similiar to yours.. I had to clock it so i could use a 45degree fitting going straight down. then a 90 degree an fitting straight to the Pan</TD></TR></TABLE>
how has that been working, any leaks or issues with backup of the oil drain?
Old Nov 3, 2006 | 06:36 AM
CBURKE's Avatar
It can't back up. The oil is droping into the hole being bushed by oil coming out of the turbo. It could maybe slow it up a little, but when you take off it would flow fine.
Old Nov 3, 2006 | 07:59 AM
EJ1 wilcox's Avatar
Default Re: (CBURKE)
^^ That CHRA looks to be way more than 30 degrees off center.
If it were me, I would change that. The CHRA should be as straight up and down as possible and no more than 30 degrees off verticle.
Old Nov 3, 2006 | 08:25 AM
drintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">It can't back up. The oil is droping into the hole being bushed by oil coming out of the turbo. It could maybe slow it up a little, but when you take off it would flow fine.</TD></TR></TABLE>
if oil flow exceeds drain capacity it will. if the angle of the drain is excessive it will create resistance causing the oil to slow. The point of the question was to see how his turbo oil seals are. I had a drain and mine looked way better then this and I had oil leaking from the turbo. Please don't post to put on a restrictor as this was not recommended by the turbo supplier. I was just wondering as there looks to be a slight up angle before the oil pan fitting.
Old Nov 3, 2006 | 09:23 AM
whiteef8's Avatar
Default Re: (drintegra)
omg, i didnt see that gold fitting at first, that drain setup is no bueno, like stated earlier, the CHRA should be no more than 30* off center, and even that is too much, man im surpried you havent eaten that turbo yet.
Old Nov 3, 2006 | 10:30 AM
CBURKE's Avatar
Well I am kinda just going by the way of "oil gets hot, oil gets thiner" I think he'll be fine.
Yes is should go up and down, but from the looks of it that is not going to happen.
Old Nov 3, 2006 | 11:55 AM
The seals have begun to leak on mine. If I clock the turbo so the drain is more vertical it will make the line totally horizontal. That brass fitting is the only one I could find that has the sharpest angle while being large enough to properly drain oil. However, this set-up is not working properly so I need to step up to -10an but I don't think that will work either. I'm beginning to think that a scavenge pump will be the best and only option.
Old Nov 3, 2006 | 12:30 PM
are u talking about his or mine?
mine doesnt go up.. from the angle of the picture, it may appear so, but it isnt..
not quite sure what u guys were sayin.. this turbo was raced on HARD for a whole season with no problems..
Old Nov 3, 2006 | 12:33 PM
CBURKE's Avatar
^^^^ I think it's fine..................
a1320honda
Dec 2, 2011 04:12 PM
central_driver
Mar 11, 2008 01:38 PM
"00"R
Jun 21, 2007 10:48 AM
Redline130
Jun 6, 2006 02:38 PM
rudebwoy
Jul 24, 2005 10:06 AM
