Spooling up questions, please help confirm the answer...
Old Feb 14, 2004 | 08:43 PM
Mr.DC2TurBo's Avatar
Default Spooling up questions, please help confirm the answer...
Hi, I just purchase a garett t3/t4e 60 trim (a/r .63) and the person who sold it to me said this turbo will spool up around 200-300 rpm faster than a garett t3/t4e 57 trim (a/r .63). Is this true??
Old Feb 14, 2004 | 09:12 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Spooling up questions, please help confirm the answer... (Mr.DC2TurBo)
That depends on a few things. It may cause of the turbo size, but I do know those turbines well enough to tell you off the top of my head. DP size, engine size, and WG setup and charge pipes all can contribute to how fast or slow you build boost. Good luck,
Blaze
Old Feb 14, 2004 | 09:13 PM
SpoolnG2's Avatar
Not at all. The trim is actually a little bigger, which means it will flow a little bit more air, but the wheels are the same and the a/r is the same, so basically you'll get almost the exact same spool up. Why would u go from a 57 trim to a 60 trim?? Theres very minimal difference.
Default Re: Spooling up questions, please help confirm the answer... (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">That depends on a few things. It may cause of the turbo size, but I do know those turbines well enough to tell you off the top of my head. DP size, engine size, and WG setup and charge pipes all can contribute to how fast or slow you build boost. Good luck,
Blaze</TD></TR></TABLE>
i no that part.. Im just saying if I have both turbo, which one would spool faster?
Old Feb 14, 2004 | 09:14 PM
Default Re: Spooling up questions, please help confirm the answer... (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Not at all. The trim is actually a little bigger, which means it will flow a little bit more air, but the wheels are the same and the a/r is the same, so basically you'll get almost the exact same spool up. Why would u go from a 57 trim to a 60 trim?? Theres very minimal difference.</TD></TR></TABLE>
I bought the 60 trim not the 57 trim but Im just curious if its true that a bigger wheel will spool faster than a smaller one?
Old Feb 14, 2004 | 09:44 PM
BlueSi2k's Avatar
Theres no way it spools faster if everything else is equal. Either same or slower since the wheel is bigger.
Old Feb 15, 2004 | 07:24 AM
Bailhatch's Avatar
Default Re: Spooling up questions, please help confirm the answer... (BlueSi2k)
yup, bigger wheel = slower spool but more flow. You could get a smaller turbine housing to bring it back down closer to the 57 trim. it will still be slower though.
dustinz_em1
Nov 25, 2007 05:41 AM
vtec.dc2
May 21, 2006 01:28 PM
the.hamburglar
Mar 4, 2006 09:34 AM
mrx
May 5, 2005 07:26 AM
eddie1681
Mar 27, 2002 02:42 PM
