Spoolin quick 4ac manifold
Old Feb 17, 2015 | 07:45 AM
BoostedEgHatchFl's Avatar
Default Spoolin quick 4ac manifold
After talking with Mac I decided to go with the silver surfer. Now I'm trying to decide what manifold to run. I really like the shorty style of the quick 4 ac. Does anyone heard good or bad about this manifold or can make recommendations?
Old Feb 17, 2015 | 08:22 AM
Schister66's Avatar
Man U FTW
Default Re: Spoolin quick 4ac manifold
I ran a similar SLS manifold and loved it for the street...the ONLY complaint I had is the oil return can be tricky if the turbo sits too low. That is entirely dependent on specific manifold design.
Phil at SPoolin gets from me - no complaints at all.
Old Feb 17, 2015 | 10:29 AM
Gotta keep ac for sure. Will have my son and wife in the car alot. It gets hot in Fl.
Old Feb 17, 2015 | 12:39 PM
Stopsign32v's Avatar
Loved
Look at the InlinePro
Old Feb 17, 2015 | 12:55 PM
Will do
Old Feb 17, 2015 | 01:18 PM
Dark_Teg's Avatar
Quick4 AC is a good street manifold. My old Spoolin tubular log was very well made.
Old Feb 17, 2015 | 03:22 PM
Found a good deal on the Inline Pro ss. Idk if it would be worth it to spend a few 100 more for a tubular manifold
Old Feb 17, 2015 | 04:02 PM
Loved
Thats the boat I'm in. I cannot think of a single reason to go with a tubular over the InlinePro
Old Feb 17, 2015 | 04:31 PM
Found one for 220 shipped with the 44mm wastegate elbow
Old Feb 18, 2015 | 05:44 AM
Schister66's Avatar
Man U FTW
Spoolin Quick4 doesn't compare directly to an InlinePro - The Quick4 has a true collector and will have less turbulent flow at higher rpms. The InlinePro is fine, but its a log manifold underneath. For $100 extra, I'd get the Quick4 or a shorty ramhorn every time over the InlinePro
Old Feb 18, 2015 | 10:11 AM
It would be 950ish shipped for the Quick4 combo. Or 530ish for the Inline pro and to have a dp build.
Old Feb 18, 2015 | 05:16 PM
805 Integra's Avatar
im also looking to get quick 4 ac from spooling and was wondering if you guys had any pics of how it would sit with the down pipe and and the compressor. anything would be greatly appreciated. found some but didn't show much. thanks
Old Feb 19, 2015 | 05:23 AM
Schister66's Avatar
Man U FTW
https://honda-tech.com/forced-induct...ld-ac-1452128/
There isn't much out there, but here's a few pictures from Project_DC2 (aka Phil at SPoolin)
Old Feb 19, 2015 | 08:30 AM
TheShodan's Avatar
Moderator
a few pictures from Lowlude22
Lowlude22
Here's his build and videos using the Quick4AC and Surfer
https://honda-tech.com/forced-induct...3017676/page5/
Old Feb 19, 2015 | 08:50 AM
DC_Legacy's Avatar
Mines got cracks between each runner/port but with that said, it's been on the motor 9yrs, countless miles and doesnt cause any performance issues in terms of heavy exhaust leaks....I should get it rewelded at the very least but I bought a SPA topmount thats going into my new setup here later this year so I might keep the SP log as a back-up manifold....
Old Feb 19, 2015 | 03:55 PM
Charlie Moua's Avatar
inlinepro cast manifold is solid and good value.
you won't have to worry about oil return line slope.
I don't recall ever seeing any data as to compare their manifold to a mini-ram.
I'm sure a decent designed miniram might free up a few poinies above 6500rpms or so but not signifcant enough to completely turn away from the inlinepro unit.
Most miniram manifolds use a pretty short collector unlike fullram,topmount,forwardfacing manifolds which use longer collectors which provide better topend flow. I think i've only see 1 miniram using longer collector... custom i believe.
Old Feb 19, 2015 | 06:40 PM
Mac told me I may run into some flow problems with it if I upgraded cams. I may stick with gsr or itr cams since it's a street car. Kinda hard to pass up the value for 200 shipped. I'll build my own dp. That's 600 dollars to go toward the turbo
Old Feb 19, 2015 | 07:55 PM
here's my miniram setup from 2yrs ago...
oil return line job from local shop... um really? lol
No seriously...
So far my best solution is pushlock fitttings/hose with crimps for insurance. Good amount of flex and plenty strong.
right on
as much as i love to get the "best" of everything... i'm a realist and drive a damn honda...so yeah, just stay clear of having a "cheapo" mentality and you should be able to easily build a solid setup without overspending.
Old Feb 21, 2015 | 05:53 AM
ef92b's Avatar
You won't get disappointed from both Mac and Phil of Spoolin'. You're in good hands.
Another Spoolin' Quick4AC/ Surfer sertup here.
As mentioned earlier, the oil return line, water supply lines and rad and fan gets a bit tricky but absolutely doable.
Old Feb 21, 2015 | 11:21 AM
Good looking setup
Old Feb 27, 2015 | 01:19 AM
Thank you guys for the pictures and link to that thread which also led me to others I was able to learn a lot from lowlude and others. I now have a better understanding of what to expect with different manifolds and turbos I will make my decision this weekend and will post up pics of my ac setup after its received to help others get a better view of clearances. Thanks.
B18T3T4
Dec 27, 2006 12:10 PM
Blindstuff
Oct 5, 2004 06:33 PM
sQwiReL bOi
Mar 23, 2004 07:20 PM
servion
Oct 1, 2002 05:12 PM
