Spool time for upgraded exhaust
Old Oct 17, 2005 | 03:41 PM
00civicsohc's Avatar
Default Spool time for upgraded exhaust
Hey i was just wondering how much faster you made full boost when you upgraded your exhaust from say, 2.25-3" or from taking out your cat converter. Also if you dynoed before and after, could you post the results and your setup. Thanks.
Old Oct 17, 2005 | 04:23 PM
N20civicB18's Avatar
Default Re: Spool time for upgraded exhaust (00civicsohc)
well i was racing someone before on my old ls setup and my exhaust let go right before the cat. so I was running open dump, the gtp was slightly pulling on me but when the exhaust went i went right by him. hmm that sounds like ricer speak right there but my butt dyno felt it i swear it gave me more power! that was a 2.25" crush bent exhaust and stock cat.
I was impressed with the spool time of my gt35r the first time I took it out but then again im running 4" all the way
You will notice a increase in spool time, there are dyno charts around here showing drastic HP increases by going from a smaller to a bigger exhaust, as for how much sooner will your turbo spool it? it all depends on the setup; but it is noticable
Old Oct 19, 2005 | 01:05 PM
Bump, anyone else?
Old Oct 19, 2005 | 03:18 PM
ProjectDarkBlack's Avatar
Default Re: (00civicsohc)
big difference. No set-up is the same though, ballpark would be maybe 500rpms at the most
Old Oct 19, 2005 | 04:28 PM
eg crunkmonster's Avatar
Default Re: (ProjectDarkBlack)
i just went from 2.3" (60mm Worldsport) to a 3" and man, this thing spools a lil bit faster according my butt-dyno . It feels a lot better now taking off. my setup is stock LS, Drag kit, 3" catback, 2.5DP
Old Oct 19, 2005 | 06:17 PM
dublaaciv's Avatar
Default Re: (eg crunkmonster)
went from 2" to 2.5" no cat no resonator now and my turbo spools 500 rpm sooner. to4b turbo. makes the car more driveable may do 3" later.
Old Oct 23, 2005 | 12:52 PM
b16adx's Avatar
On my drag kit on jdm gsr motor I went from approx 2.5 exhaust/dp and cat to 3 in exh/dp and no cat and my spool time went from 4400 to 3500 and i gained 40hp and 20lbs of tq still running the same 9 psi..retuned of course
Old Oct 23, 2005 | 04:48 PM
So hopefully from my going from 2.25 to 3" i will spool even faster then you did. Also how bad would it be to drive without it getting retuned? I will be getting it retuned but should i take it easy before i do that?
Old Oct 23, 2005 | 04:53 PM
i was driving around with no retune on my 3", still felt good and i pushed it every minute for about 2 weeks.
chriskey0829
Mar 10, 2006 02:11 PM
B18Sleeper
Nov 3, 2005 08:01 AM
Sinner
Dec 24, 2003 06:11 PM
SebAyatollah
Mar 13, 2003 12:43 PM
JM Performance
Sep 27, 2001 01:14 PM
