Spitting and Sputtering on Boosted Integra
Old Dec 10, 2006 | 02:36 PM
FrOsTwHiTeDC4's Avatar
Default Spitting and Sputtering on Boosted Integra
My friend has a boosted 95 SE with a 50 trim blah blah blah. When he is driving as soon as he hits full boost (11.7psi wastegate spring) his car spits and sputters. He is running stock injectors and MAP with an SAFC. It is a 50mm wastegate and we can't seem to figure out why it's doing this. Any help would be appreciated. Any info needed just ask!
TIA
Albert
Old Dec 10, 2006 | 02:39 PM
CustomX113's Avatar
Banned
could be to much fuel or not enough its the tune... the stock maps are suppose to be good for 10 psi or so, but i have used a stock one on 15 psi...
Old Dec 10, 2006 | 02:40 PM
CustomX113's Avatar
Banned
and i just noticed your running stock injectors which probably means your using the stock fuel pump as well..
Old Dec 10, 2006 | 02:47 PM
Default Re: (95dxb18c1)
yea stock both. when in a higher gear 4th/5th it hits boost and throws a code also. Do you think injectors could be the problem?
Old Dec 10, 2006 | 02:53 PM
93turbo16's Avatar
Does the search button or FAQ mean anything these days.
Spitting and sputtering, because you are lean as **** and more than likely detonating the **** out of the motor. Throws a MAP code because you if you have a map bypass it isn't working or you don't have one, and in that case that is the problem.
1) Get bigger injectors.
2) take out that damn SAFC.
3) Get good management.. crome/neptune/uber/hondata.
Take it to a tuner, problems fixed.
Old Dec 10, 2006 | 02:59 PM
CustomX113's Avatar
Banned
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Does the search button or FAQ mean anything these days.
Take it to a tuner, problems fixed.</TD></TR></TABLE>
255 walbro would be a nice investment as well
Old Dec 10, 2006 | 03:01 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
255 walbro would be a nice investment as well</TD></TR></TABLE>
Yes. I found that mine wouldn't handle anything more than 8 psi on my stock pressure and stock pump. So a 255 would be a good idea.
DJ Gurgla GSR
Feb 16, 2006 10:55 AM
Hyper16-Johnny
Jan 6, 2006 06:13 PM
desert eagle
Aug 24, 2004 11:25 PM
doberwing
Apr 5, 2004 07:45 PM
99lspwr
Oct 24, 2003 09:12 AM
