spitting and sputtering b16 again please help!!!
Old Mar 14, 2003 | 07:44 PM
spooled b16's Avatar
Default spitting and sputtering b16 again please help!!!
My car is running like crap again. First it was hesitating and then surging kind of like if you were to let off the throttle and then slam it repetively to make it jerk back and forth. So I found out my fuel preasure was too high at idle like 50psi due to my fpr getting no vac. so i hooked it directly to the manifold and it brought fuel preasure down to 37psi and everything was fine.
Now 3 months later its doing it again and I don't know why, im not throwing any codes, but my a/f meter is pegged rich at idle like before sometimes at idle it will even die, it did this before as well until i fixed it and now its doing it again
any advice besides going stand-alone
Old Mar 15, 2003 | 07:12 AM
turbosol's Avatar
Default Re: spitting and sputtering b16 again please help!!! (spooled b16)
Injector size? AFC? fpr? need more info.
Old Mar 15, 2003 | 04:24 PM
tSuperbike69's Avatar
Default Re: spitting and sputtering b16 again please help!!! (turbosol)
Need more info but if it is just happing at idle try to clean out your iac motor
Old Mar 16, 2003 | 06:19 PM
Default Re: spitting and sputtering b16 again please help!!! (tSuperbike69)
I cleaned out the iac a while ago, and all i have is the fmu no adjustable fpr and the injector size i don't know. I have heard people say the injectors don't look stock. It does it at idle and when i begin to go it bogs down like it's almost completely dead and then it surges after the bog. It seems to be doing it more often since i changed the fuel filter. hopefully i can get to my mechanic tomarrow
Old Mar 17, 2003 | 08:45 AM
nitroice40's Avatar
I am having the same problem. Let me know when you find out what it is?
thanks
ncsi
Jan 3, 2012 03:08 PM
boostedh22a
May 6, 2006 05:58 PM
ExVtec
May 16, 2004 07:48 PM
turbod16y7vtec
Nov 2, 2002 07:43 AM
White98LS
Jul 23, 2002 09:21 AM
