spiro locks! WTF!!!!!!
Old Apr 21, 2004 | 07:33 PM
Matt B's Avatar
Default spiro locks! WTF!!!!!!
I can't get these bastards on. there is no screwing it in, that crap won't bend. How did you guys install these?
dfoxengr's Avatar
Default Re: spiro locks! WTF!!!!!! (Matt B)
what are they? pics?
Old Apr 21, 2004 | 08:28 PM
raene's Avatar
LOL, Rimmer
Old Apr 21, 2004 | 08:30 PM
Kataku2K3's Avatar
Default Re: spiro locks! WTF!!!!!! (hybridvteceg)
You should be able to thread them in place. Did you put on in first without the wristpin/rod in place then work on the second?
Old Apr 21, 2004 | 08:43 PM
Matt B's Avatar
Default Re: spiro locks! WTF!!!!!! (Kataku2K3)
are they meant to be so tight? i can pull them apart but they pinch the **** out of my fingers and they won't "thread" into the hole. my piston is getting all scratched up.
Old Apr 21, 2004 | 08:53 PM
Kataku2K3's Avatar
Yea, they're supposed to be tight, I have yet been able to do it without scratching the piston (no matter how careful I am) but they are a little bit more work than C-clips. Just keep trying, you'll get it.
Old Apr 21, 2004 | 09:00 PM
Matt B's Avatar
i think the main problem is that the end is sharp and digging into the groove not allowing the lock to turn. Would it be alright to file the end a little?
Old Apr 21, 2004 | 09:25 PM
PrecisionH23a's Avatar
Get some 'dental pick tools' then simply start with the open end closest to the wrist pin and 'spiral' the lock into place.
It's as easy as that.
Old Apr 21, 2004 | 09:40 PM
MikeMAN's Avatar
if you cant find dental type tools, a simple soldering tool from radio shack will help 10000 fold. Its really sharp/fine picking tool for soldering.
mike
Old Apr 21, 2004 | 10:13 PM
earl's Avatar
Default Re: spiro locks! WTF!!!!!! (MikeMAN)
Some builders stretch them out so they look like a spring and then re compress them as they screw them in.
If you used CP', you would not have to deal with those things.
Old Apr 21, 2004 | 10:17 PM
Default Re: spiro locks! WTF!!!!!! (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Some builders stretch them out so they look like a spring and then re compress them as they screw them in. </TD></TR></TABLE>
Yep, that is what I have done in the past.
Old Apr 23, 2004 | 12:20 AM
boosted15's Avatar
if your trying to screw the spiral lock in it won't work. try getting one end of the lock in ,then use your thumb and start pushing the lock down, push the first spiral turn closest to the wristpin and work the whole lock in til it locks in the groove.
JozGri
Welding / Fabrication
Jul 25, 2012 12:54 AM
untitledsn41
Jul 29, 2004 01:34 PM
Batoutahell
Mar 15, 2004 09:07 PM
216.226.142.95:27016
May 17, 2003 10:43 PM
