speedpro hook up question?
o.k. I have the whole unit hooked up in my car I would start the car if my damn motor gets back from machine shop, but my question is, do you need a relay for vtec power?Also is vtec the black wire that says ESC?I have heard different things, i was looking in the speed pro control panel briefly, since I dont have my laptop hooked up right now I cant see further features, but I see no control for a rpm acctivated device? how does everyone with speed pro hook up there vtec? Jason
you have got to have atleast one rpm window switchbale input on the speedpro, is your fan hooked up to the speedpro or thermostat relay??? you may be able to put your fan on a rocker switch manually and use a rpm switch for the fan on the speedpro set by rpm???? you should have some rpm triggers added to your speedpro, send it back for upgrades - what model and options do you have????
[Modified by rtype11, 1:44 PM 3/19/2002]
The fan ground is setup for temperature trigger not rpm , I will keep looking for rpm setup, but the only external wire that is unknown is the esc I think it is knock.Jason
the ESC is for knock control. its possible to use the nitrous function and a relay to activate vtec, but it is universally known the simplest way to do this is with a msd activated switch.
[Modified by SEFI8LOxCivic, 1:59 AM 3/20/2002]
Tinker219
Sep 17, 2004 04:15 AM
project dc2
Dec 24, 2002 06:49 AM
CimorelliCRX
Jul 29, 2002 11:12 AM
