Spark Plug Readings
Old Mar 22, 2002 | 10:15 AM
Nfurno's Avatar
Default Spark Plug Readings
I took out my plugs today to see what they look like, since I hadn't done it in a while. I know i'm running rich because they are black, but what concerns me most is that there is some speckly deposits on it. Can I also be detenating? The car seems to run fine. By the way, I use a mixture of 100 octane and 91 octane when I full up. I'll try to post some pictures if I can get my hands on a digital camera.
Thanks
Old Mar 22, 2002 | 10:21 AM
ATurboCivic2NV's Avatar
Default Re: Spark Plug Readings (Nfurno)
how do you get a mixture of 100 and 91 octane?
Old Mar 22, 2002 | 10:27 AM
Nfurno's Avatar
Default Re: Spark Plug Readings (ATurboCivic2NV)
There's a 76 station that sells 100 octane in my area. I usually put like 4 gal. of the 100 octane then fill the rest up with 91.
Old Mar 22, 2002 | 12:37 PM
phildeez's Avatar
white speckles usually means that your detonating, but i think you know that.
also, it can mean that you have water in your combustion chamber,i.e. broken head gasket, or sucking in water.
Old Mar 22, 2002 | 01:43 PM
Nfurno's Avatar
Default Re: Spark Plug Readings (phildeez)
I thinking I might of had alittle detination by looking at the tops of the pistions through the spark plug openings, but I'm thinking that the speckles might be from octane boost or fuel additives.
Old Mar 22, 2002 | 06:13 PM
SIK IN DA HED's Avatar
New User
so what does it mean when you have whitish coloring around the edges of the plug? its more faded white color than black.
Old Mar 22, 2002 | 07:40 PM
phildeez's Avatar
Default Re: Spark Plug Readings (dlplayboy)
i think if it is a grey color and smooth then it is fine, but if it looks all tore up and white then you runnin lean. please correct me if im wrong, cause my plugs look like that.
BIGef
Sep 24, 2013 02:37 PM
megaman096
May 27, 2006 05:15 PM
Power Rev Racing
Aug 7, 2005 08:16 AM
matman4444
Jun 17, 2005 01:26 PM
