spark plug questions
Old Mar 29, 2009 | 01:23 PM
csubucky19's Avatar
Default spark plug questions
2.0 gsr motor
9.5.1 compression
440 hp at 24psi
only run like 19 psi on the street
i am running the ngk v power plugs r5671a-9
is this plug right for this power level?
what should i gap to?
car is sputtering on a new set of plugs after about 300miles. 2 19 psi pulls couple more at 14 psi and about 300 miles of highway driving. sound normal?
Old Mar 29, 2009 | 02:05 PM
Gkdc182's Avatar
Default Re: spark plug questions
I would run NGK Iridium IX Spark Plugs heat range 8...gapped around 25
Old Mar 29, 2009 | 03:23 PM
csubucky19's Avatar
i thought i read that iridium are not good. people having probs with the tips breaking off. copper is better right?
Old Mar 29, 2009 | 03:58 PM
Joseph Davis's Avatar
Cheap iridium are not good. Avoid Denso, Bosch, etc, as I've never had a good experience with any of their plugs in a performance application. I wasn't a big fan of iridiums for a long time, but after talking long and hard with a rep at PRI, harrassing NGK via phone, and using enough NGK Iridiums I'm a believer.
I also like the older non-resistor steel electrode NGK race plugs, R5671A-x. In a B-series you'll want an 8, so R5671A-8. It's what I'd run, the only reason to go to iridiums on a B-series is if you have a Hondata S300; their daughterboards are poorly shielded and susceptible to EMI.
Old Mar 29, 2009 | 05:09 PM
csubucky19's Avatar
i am running s200.
Old Mar 29, 2009 | 07:31 PM
welfarepc's Avatar
iridium is around 600% harder than a conventional copper core tip and will produce a better spark.
Old Mar 29, 2009 | 07:32 PM
welfarepc's Avatar
go on... what about a chipped obd1 with lets say ectune.
i ran r5671a's for a while without issue w/ obd0. they are cheap, and come real cold.
Old Mar 29, 2009 | 07:36 PM
V-SPEC 1's Avatar
2.0 gsr motor
9.5.1 compression
440 hp at 24psi
for that psi level of 19 on the street, I'll use the ngk 7 and gap them at around .025-.028
Old Mar 30, 2009 | 07:53 AM
csubucky19's Avatar
care to share a part number?
or should i just use what is reccomended for my car but in a 7 heat range?
Old Mar 30, 2009 | 08:42 AM
jfoster's Avatar
isn't ngkbkr7e kinda the standard?
Old Mar 30, 2009 | 09:06 AM
boosted k20's Avatar
i would go with 8's part number 4554
Old Mar 30, 2009 | 10:12 AM
Ls_dx's Avatar
those are the cats pajammas... I keep like 5 sets on hand at all times. the only plug IMO
Old Mar 30, 2009 | 11:29 AM
werd.
7's seems too hot for your setup and HP range.
Old Mar 30, 2009 | 11:50 AM
TehGhett0P1mp's Avatar
So the ngk racing plug over the brk7e? Or would the racing plug be better only if you have s300?
Old Mar 30, 2009 | 04:11 PM
welfarepc's Avatar
can you read? do a google search on EMI and the purpose of a resistor plug.
Old Apr 4, 2009 | 06:37 PM
As other's have stated, R5671A-8 aka 4554 is the all-around plug people use with B-series. By the time you max them out and upgrade from pump gas they are perfect again. I've made 804 whp off of that plug and eCtune if you're worried about the combo.
You're going to be hard pressed to find a copper tipped plug. Copper core, maybe, but not tip.
I've never seen a comparison involving an iridium, but I doubt they produce a better spark. The pointy tip of an iridium - much like platinum, or "funny" shaped electrode plugs - makes it easier for the ignition energy to jump the plug's airgap which dictates a weaker spark. GRM did an article on this 8-10 years back, and V=IR with and eye to P=VI (basic equations for the relationships of voltage, amperage, resistance, and power) concurs.
That being said, as long as the plug works then don't worry about it. It's splitting hairs.
b00stedbyFastrax
Jun 9, 2008 11:22 AM
eg:R
May 21, 2006 08:53 AM
RTW DC2R
Apr 10, 2004 05:23 PM
aznchino16
Apr 8, 2002 01:25 PM
